Does anyone know how to take these off - Mustang Evolution
Old 03-29-2013, 09:09 AM   #1
greenstang41's Avatar
greenstang41 is offline   Reply With Quote
Old 03-29-2013, 09:16 AM   #2
brooksyx's Avatar
The pin stripes?
I am not sure about those but I had a 93 ford ranger stx. The stx package came with these silly purple and blue stripes. Got it off with a hair blow dryer and razer blade, just went very slow. Tried a heat gun but it was too hot and left the sticky residue on the car.
Here is what my truck looked like before and after:
brooksyx is offline   Reply With Quote
Old 03-29-2013, 09:37 AM   #3
Ok I'll try it
Old 03-29-2013, 09:46 AM   #4
Mustang81596's Avatar
Not trying to jack your thread, but how much would it be to get it re striped? Mine look really bad..
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 03-29-2013, 09:57 AM   #5
brooksyx's Avatar
Looks like this might be better for the cars paint than a razor blade:
3M-7498 STRIPE WHEEL W/ARBOR - Amazon.com
Any tips on how to remove pinstriping? - The Mustang Source - Ford Mustang Forums
Howerver I just used a cheap inch long razor to get it started/get hard spots and just made sure to keep it real flat against the car.
Old 03-29-2013, 10:08 AM   #6
V6in's Avatar
I used a hair dryer and peeled it all off then used goo gone to get the left over residence off
V6in is offline   Reply With Quote
Old 03-29-2013, 01:43 PM   #7
Xaperez100's Avatar
I used a razorblade to get it started then as soon as I got some off I peeled the rest with my hand. And came out nice:p
Xaperez100 is offline   Reply With Quote
Old 03-29-2013, 03:15 PM   #8
Torchredfrankie's Avatar
That what I did with my 98 then just use rubbing compound to take off any dirt marks that's left behind
Torchredfrankie is offline   Reply With Quote
Old 03-30-2013, 09:07 AM   #9
BloodRedStang's Avatar
try to avoid a razor blade. get some plastic scrapers and use those. use a hair dryer and move slow. once you're done use a mild degreaser to get any left over gunk off and maybe polish the car afterwards.
BloodRedStang is offline   Reply With Quote
Old 03-30-2013, 04:39 PM   #10
I would heat them up and pull them off and if their is residue compound will take that off.
Redstang19 is offline   Reply With Quote
Old 03-30-2013, 05:51 PM   #11
+1000
Old 04-04-2013, 04:01 PM   #12
Has anyone had the problem of this while taking them off? It's only on the passenger side..
Old 04-04-2013, 04:10 PM   #13
No they are easy to take off just make them hot with a heat gun and start pealing them off.
Old 04-04-2013, 04:28 PM   #14
I think my car may have been repainted cuz there's a lift at the bottom of the pinstripe about .25 of a millimeter. And it goes down the entire passenger side, but not the drivers
Old 04-04-2013, 10:29 PM   #15
Only way to find out is take them off.. a lot of times they will lift a tiny bit at the edges.. same thing happened on a firebird I had and I thought it had been painted but it was the top layer of the pin stripe lifting.
Old 04-05-2013, 04:17 PM   #16
dank_ryan's Avatar
This is what you need! Label n sticker remover by turtle wax. Works great and there is no rick of ruining your clear coat finish. Let me know if this helps
dank_ryan is offline   Reply With Quote
07:22 AM
