Keyless entry. - Mustang Evolution
Old 03-29-2013, 07:19 PM   #1
Robbiemustang96's Avatar
Keyless entry.
How can i find out if my car has keyless entry and if it doesnt can i get the modual somehow?
Robbiemustang96 is offline   Reply With Quote
Old 03-29-2013, 07:50 PM   #2
v8pony's Avatar
Get in your car, put your key in the ignition, turn it to the on position and than to the off position, do that 8 times, if your door locks jump up and down you have keyless entry, you can buy one on eBay for cheap and program it by doing the same thing with the key 8 times, than when locks start to jump you press lock/unlock on the keypad or something along those lines.
2002 5spd GT
Feb 2013 Mustang of the Month
Old 03-29-2013, 09:02 PM   #3
Ghostedmind's Avatar
They cost about 4 bucks, they tell you to turn your ignition to on (but not running) and back to off 8 times within 10 seconds. If you already have the box then you press the lock button on it and the locks will cycle. You have 10 seconds to press the lock button on each key fob.
I have two. One I keep inside the house in case I ever lock my keys in the car lol
LCMC Member
Old 03-29-2013, 09:34 PM   #4
also the module is in the trunk on the drivers side i think you can look for it there, its on one side its a box like thing
Old 03-29-2013, 09:38 PM   #5
Is it realiy?! That makes me feel stupid lol ill check tomarrow then...
Old 03-30-2013, 11:36 AM   #6
Welp i dont think i have keyless entry.. Or do i
Old 03-30-2013, 03:27 PM   #7
98mustang11's Avatar
I found that when I was putting in my shocks am wondered what that was... Mine is empty to
98mustang11 is offline   Reply With Quote
Old 03-30-2013, 03:37 PM   #8
So you dont have keyless entry either?
Old 03-30-2013, 03:39 PM   #9
Don't think I do I got a remote with the car but that's just cause the guy I got it from seen it at the auction and grabbed it
Old 03-30-2013, 03:47 PM   #10
Oh.. Has it ever worked? I just dont have a remote... And i tried that 8 times back and forth thing and nothing happend... I just dont think i did it right....
Old 04-03-2013, 11:39 AM   #11
Joestang83's Avatar
The other method to try is to short the two metal pins inside the grey connector while the key is in the ignition in the on position. Locks should cycle, then push the lock/unlock button(s) to see if they lock/unlock with the remote fob. Easy to do!!
Joestang83 is offline   Reply With Quote
Old 04-05-2013, 05:29 AM   #12
BloodRedStang's Avatar
That's odd, that looks exactly like the one in my trunk but I have keyless entry..
BloodRedStang is offline   Reply With Quote
Old 04-05-2013, 02:25 PM   #13
Is something hooked up in that spot in your trunk? I have the same hook up but nothing is there
Old 04-05-2013, 03:04 PM   #14
Joestang83's Avatar
The control module for the system is located behind the black plastic frame, next to the body. You can't really see it clearly without getting right up to the frame. Hope this helps!!
12:11 AM
