Transmission fluid location? - Mustang Evolution
Old 03-30-2013, 04:03 PM   #1
SpeedyG's Avatar
Where can I find the spot to put in Lucas transmission fix fluid? 2000 v6 vert
SpeedyG is offline   Reply With Quote
Old 03-30-2013, 05:01 PM   #2
BatmanUriah's Avatar
If you don't have a dipstick for your transmission, then you'll have to crawl under the car and pump it in.
BatmanUriah is offline   Reply With Quote
Old 03-30-2013, 05:03 PM   #3
sam62893's Avatar
You just use the dipstick tube with a long funnel. It is on the left had side of the engine bay (passengers) side near the firewall
Old 04-01-2013, 05:22 PM   #4
SpeedyG's Avatar
I don't think I have a dipstick for my manual transmission. I looked everywhere for it. I think I might have to put it in from under the car.
Old 04-01-2013, 10:40 PM   #5
sam62893's Avatar
Ohhhhh. I don't know about stick. But automatics have the dipstick. Maybe someone will say something soon
Old 04-01-2013, 10:55 PM   #6
1slosix's Avatar
it's easy on a 5 speed...take off the shifter bezel and unbolt the shifter...pull it up and out then pour the fluid in. put some rtv down to reseal the shifter and reverse the steps.
carving corners like a boss
Old 04-04-2013, 08:35 AM   #7
SpeedyG's Avatar
So the trany fluid fluid goes through under the shifter? That's pretty easy. Will try it out. Thanks!
Old 04-04-2013, 11:22 AM   #8
1slosix's Avatar
No biggie hope it helps
Old 04-05-2013, 01:31 PM   #9
SpeedyG's Avatar
Anyone know how much how much Lucas transmission fix should be added? Don't wanna go overboard.
Old 04-05-2013, 05:07 PM   #10
Attachment 100617
Usually the bottle will have instructions, and let you know how much to add. Are you only adding some of the Lucas oil, or are you draining all of the old fluid, and then adding lucas to the new mix?
Old 04-05-2013, 08:34 PM   #11
SpeedyG's Avatar
Just adding
Old 04-05-2013, 09:26 PM   #12
1slosix's Avatar
you really don't wanna overfill it....i know on my t3650 it took 3.25 qrts when i did my flush and fill
Old 04-06-2013, 12:35 PM   #13
SpeedyG's Avatar
After after adding the Lucas transmission fix I have to say what a great difference. I have a stock shifter and it was shifting EXTREMELY hard, at the same time my steering wheel and car would shake alot getting through 1,2,3 gears, it would smooth out at 4,5. Now after adding a half bottle of Lucas getting off the line is smooth with no shaking and the shifts are smoother. Eventually I have to service the whole transmission but for now this is a good fix. I recommend this product.
Old 04-06-2013, 03:20 PM   #14
Right on. Glad it worked out for ya.
09:53 AM
