Need help - Mustang Evolution
Old 03-31-2013, 12:26 PM   #1
Need help
Hello
I have windstar engine 1999r XF2E-AD and I want to swap to the mustang 1995r
What flywheel i needs?
Thank you for your reply
michal1985 is offline   Reply With Quote
Old 03-31-2013, 12:49 PM   #2
Ghostedmind's Avatar
if you're talking about the 1995 Mustang Cobra R engine then you need the flywheel specific to that engine.
Here is one that I've found, but by no means is this the only one
Mustang 1995 5.8L Cobra R Steel Flywheel [ SF82S ] - Spec Clutch Superstore - All your Clutch needs from Spec
LCMC Member
Old 04-01-2013, 03:49 AM   #3
I have 1995 mustang 3.8 v6 manual which engine was explode I bought engine from windstar 1999r 3.8v6 split port with automatic transmission and externally balance crankshaft and I can not get find a suitable flywheel with balance.
For instance it fits the Mustang 1999r 3.8 v6?
08:49 PM
