New problem - Mustang Evolution
Old 03-31-2013, 06:22 PM   #1
sam62893's Avatar
So my service engine light came on and I got me an awesome OBDII reader that works with my phone. How can I start with fixing this? And the second picture is my car while idling. Is this correct or is there something wrong with my car?
ID:	99708   Click image for larger version
Old 03-31-2013, 08:24 PM   #2
tonyd01gt's Avatar
Check the plug on #1 cylinder, and wire,or COP.
tonyd01gt is offline   Reply With Quote
Old 03-31-2013, 08:56 PM   #3
sam62893's Avatar
What is the COP?
Old 03-31-2013, 09:03 PM   #4
Ghostedmind's Avatar
coil on plug, you probably dont have that, more than likely you have a coil pack mounted on the upper intake with wires leading to each plug. either way tony is correct. first thing would be to find the number 1 plug and check the connections all the way to the coil pack
LCMC Member
Old 03-31-2013, 09:12 PM   #5
sam62893's Avatar
Perfect. Thanks. Yeah, I have the newer NE engine so I have the coil pack. Ill check that out and report back, hopefully it's a spark plug. I have a spare set of wires, plugs, and a coil pack.
Old 03-31-2013, 09:32 PM   #6
Boomdizzle's Avatar
Pretty sweet app. I does that hook up through blue tooth?
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 03-31-2013, 10:32 PM   #7
sam62893's Avatar
Nah, it connects through wifi. It's called the ELM327 OBDII port. There's a Bluetooth one and the wifi one. Both require a third party software. The iPhone one was expensive but damn worth it
Old 03-31-2013, 10:42 PM   #8
Robbiemustang96's Avatar
Where did you find the adaptor plug? At like best buy or walmart or something?
Robbiemustang96 is offline   Reply With Quote
Old 04-01-2013, 06:20 AM   #9
sam62893's Avatar
Amazon. It's like 30 bucks and the app cost about the same. The Bluetooth one is much cheaper though
Old 04-01-2013, 06:32 AM   #10
Wow.. Ok lol thanks
Old 04-01-2013, 06:50 AM   #11
bucko's Avatar
The great thing with owning a code reader is that you can take the read code, enter it into a Google search, and get hundreds of responses; they will explaing the code, the symptoms, and solutions.
getting the reader was the hard part; the rest is simply just reading and learning.
Old 04-01-2013, 07:01 AM   #12
v8pony's Avatar
Just grabbed a Bluetooth obd2 reader from eBay for 12$
2002 5spd GT
Feb 2013 Mustang of the Month
Old 04-01-2013, 07:05 AM   #13
You can also get a haynes book.. They have the codes in there
Old 04-01-2013, 07:13 AM   #14
v8pony's Avatar
+1 I just noticed that the other day randomly browsing the book
2002 5spd GT
Old 04-01-2013, 07:19 AM   #15
I noticed it when i first bought the book...
Old 04-01-2013, 10:49 PM   #16
sam62893's Avatar
The app is amazing and worth the money it's like exactly like having a handheld code reader only better. It gives you the code and the diagnostic. Gives you a bunch of info too. So I checked the #1 wire and it was good, coil pack all good but the spark plug was crap. I took off two more plugs and they were pretty worn but not too bad. I replaced the worn out plug with a spare I had on another motor and it runs good, no more bogging down and no more popping noises. I'm going to replace all plugs and wires eventually. But what had me concerned was that there was a bit of oil on the threads of the plugs. Is this normal?
ID:	99937   Click image for larger version
Old 08-07-2013, 08:44 PM   #17
elm327
hellozaizai is offline   Reply With Quote
12:25 PM
