Battery problem? - Mustang Evolution
Old 04-01-2013, 04:49 AM   #1
TM2189's Avatar
Battery problem?
So I got my 96 back together hooked everything up and went to start it up, I put the key in the ignition and all the lights came but when I turned the key I heard a single click then all the lights went dim. I know 100% that there's nothing wrong with the starter. What could it be?
TM2189 is offline   Reply With Quote
Old 04-01-2013, 06:47 AM   #2
Robbiemustang96's Avatar
That click is the starter solinoid connecting... Most likely your batter is low. Charge your battery and then try.. Have you had to disconnect the battery for some reason?! And maybe taken it out and put it on concreate?! Because concrete will drain your battery
Robbiemustang96 is offline   Reply With Quote
Old 04-01-2013, 07:34 AM   #3
TM2189's Avatar
I've had it charging all night, I tried again and the engine turned over this time. Tried it a second time and all the lights dimmed and nothing else happened.
Old 04-01-2013, 08:05 AM   #4
YELLERSTANG02's Avatar
its either a bad connection ,check your cables make sure there tight and clean.if still not,then sounds like the battery may have gone bad on ya.
YELLERSTANG02 is offline   Reply With Quote
Old 04-01-2013, 11:58 AM   #5
How old is your battery? If it was all the way dead then it could take up to a day to get to 12 volts..
Old 04-01-2013, 07:01 PM   #6
TM2189's Avatar
The battery was one I got free, the positive post is loose so I'm guessing I should just get a new battery?
Old 04-01-2013, 07:05 PM   #7
Yep get a good one as in a interstate megatron those are some of the best batteries out there... I run them in everything..
03:39 PM
