O/D Question - Mustang Evolution
Old 04-02-2013, 09:29 AM   #1
XSlashDashX's Avatar
O/D Question
When I I turn off overdrive and drive around for about 5 minutes, the temp gauge rises. Is that normal?
Old 04-02-2013, 09:32 AM   #2
kickerofdoom's Avatar
The engine is running harder so I think yes
Old 04-02-2013, 09:34 AM   #3
So is it bad to turn off overdrive?
Old 04-02-2013, 09:38 AM   #4
More wear and tear on the motor. I don't mess with it. Sometimes if I want to be in the gear longer maybe.
Old 04-02-2013, 09:46 AM   #5
Alright, thanks. I figured overdrive didn't hurt until i saw the temp gauge rise. Thought overdrive was there only to save mpg.
Old 04-02-2013, 09:52 AM   #6
Well it saves gas by changing into the next gear. The lower the rpms less gas,wear on the motor and trans
Old 04-02-2013, 05:29 PM   #7
Justasix98's Avatar
If your temp is rising its not the o/d.. Have you checked for leaks or anything like that ? All the o/d does is keep it in a lower gear, to save mpg and that's only if your going above 45 mph...
---------- Post added at 05:29 PM ---------- Previous post was at 05:28 PM ----------
For instance if your cruising at 50, od off, your in 4th gear. If you hit the o/d button it'll kick it into 3rd
Just A Sixxer!
Proud member of WickedStangs Okc Chapter!
Justasix98 is offline   Reply With Quote
Old 04-02-2013, 05:45 PM   #8
Isn't overdrive 4th gear in our cars too?
Redstang19 is offline   Reply With Quote
Old 04-02-2013, 05:45 PM   #9
Justasix98's Avatar
Yup
Just A Sixxer!
11:44 PM
