98 v6 8.8 swap - Mustang Evolution
Old 04-02-2013, 04:22 PM   #1
Fourloko530's Avatar
98 v6 8.8 swap
So what size gears r the 94 to 98
And can i use 99 and up gt end what gears do they use
Fourloko530 is offline   Reply With Quote
Old 04-02-2013, 04:56 PM   #2
You'll have no problem using a 94 - 04 rear end. The gears in the 94 - 98 were either 2.73 or 3.08 gearing, you have to make sure on the tag on the rear end to know which one you are getting. The 99 - 04 were all a 3.27 gearing, 3.55 for mach 1 and cobra I think.
Redstang19 is offline   Reply With Quote
Old 04-02-2013, 05:07 PM   #3
? Is can i fit from 99 to 04
Old 04-02-2013, 05:19 PM   #4
Yes you can put a 99 - 04 rear end in your car.
Old 04-02-2013, 05:58 PM   #5
1slosix's Avatar
in fact a 99-04 rear would even fill out the back a bit better on your car due to being wider just make sure to recal the speedo
carving corners like a boss
Old 04-02-2013, 06:21 PM   #6
What else has a 8.8 and 3.55 gears that i can get from
Old 04-02-2013, 07:23 PM   #7
Probably some trucks like an F150 or Explorer but I'm not sure. It's just easier to swap from another Mustang though.
Old 04-02-2013, 07:49 PM   #8
So mach for good gear
» Members Mustangs
Katy
Gio_5.0
Dubya
Dubya11
Add your Mustang
11:59 AM
