Windstar Manifold bolts - Mustang Evolution
Old 04-07-2013, 03:28 AM   #1
willrad00's Avatar
While i was doing the windstar swap a while ago i snapped a couple of the bolts that directly hold the manifold down. To finish the job quickly i used the stock ones with a ton of washers, but now that i'm trying to clean the engin bay i want to get all those rusty washers gone. My question is does the unthreaded part of the bolts seal oil or any other fluid in the motor, or could i just use fully threaded bolts? Thanks
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 04-07-2013, 09:04 AM   #2
sam62893's Avatar
I'm not to sure about that, you can just get the wind star bolts from the junkyard from another wind star can't you?
Curious question though. How did you get the windstar to fit under the hood of your car without raising or something?
Old 04-07-2013, 09:22 AM   #3
I don't think their is any fluids in that part of the engine anyway, I could be wrong though the coolant might be going through there.
Redstang19 is offline   Reply With Quote
Old 04-07-2013, 09:37 AM   #4
sam62893's Avatar
I don't think there is.
I mean the manifold bolts right on to the lower manifold straight to metal the only thing that passes through them is air.
Old 04-07-2013, 02:57 PM   #5
Tyoung68's Avatar
Its probably more to line everything up than to seal it
Old 04-07-2013, 05:13 PM   #6
willrad00's Avatar
Ok, so i should be able to just use normal bolts? And Sam it fitted fine with an angled throttle body spacer and removing the hood insulator!
Old 04-07-2013, 05:49 PM   #7
Tyoung68's Avatar
Yeah you can always just put some silicone on it to
Old 04-07-2013, 05:58 PM   #8
Ghostedmind's Avatar
i'm pretty sure the bolts just go straight through, they dont seal anything
LCMC Member
Old 04-08-2013, 03:20 AM   #9
willrad00's Avatar
Sweet, I'll go pick up some full threaded bolts in the right size then. Thanks for the help guys
08:18 PM
