Engine startup - Mustang Evolution
Old 04-07-2013, 08:43 AM   #1
TM2189's Avatar
Engine startup
I fixed my electrical problem so the starter engages, but the engine won't start. Any easy to overlook suggestions? 1996 mustang
TM2189 is offline   Reply With Quote
Old 04-07-2013, 09:18 AM   #2
Is the engine cranking strong now? If it is it's probably the fuel pump, it crapped out at some point and is not sending any fuel to your engine. Turn on the car with the everything off like the heater or radio but without starting the engine and try to listen for the fuel pump turning on or not.
Redstang19 is offline   Reply With Quote
Old 04-07-2013, 09:24 AM   #3
TM2189's Avatar
Thanks, I'll check that.
Old 04-07-2013, 03:03 PM   #4
Tyoung68's Avatar
You need three things to start your engine. Air, fuel, and spark. You are getting air so next would be check fuel and spark. You can disconnect your fuel injection and pull a wire off of a plug and stick a screw driver in it and hold it just barely away from your engine block and see of it sparks and if it doesn't then thats your problem and if it doesn't then its your fuel system
Old 04-07-2013, 03:07 PM   #5
sam62893's Avatar
Can't you also check the spark with the distributor? Or in this case the COP or coil pack? Haven't tried it yet but with my 66 I just take a plug off the distributor cap and check the spark that way
Old 04-07-2013, 03:18 PM   #6
Tyoung68's Avatar
I havent heard that way but this way you can check wires too
Old 04-07-2013, 05:20 PM   #7
The fuel system will always fail before the electrical system unless something weird has happened. That's what I've always been told.
Old 04-07-2013, 08:31 PM   #8
TM2189's Avatar
This is the fuel filter, does it look like it may be the problem?
Old 04-07-2013, 08:36 PM   #9
TM2189's Avatar
Also to see if the fuel pump works can I just turn it on to see if gas squirts out not that the filter is off?
Old 04-07-2013, 09:03 PM   #10
Tyoung68's Avatar
You can put a fitting on your fuel rail and attach a hose to it and squirt it in a bottle
Old 04-07-2013, 09:54 PM   #11
TM2189's Avatar
Ok so I turned in the car and fuel went thru where the fuel filter was. Does this mean I just had a bad filter?
Old 04-07-2013, 10:02 PM   #12
Ghostedmind's Avatar
possibly, basically all that eliminates right now is your pump. once you get a new filter in there try it again, after that is your injectors. unless there is a blockage in the lines somewhere. for which you could hook up a fuel rail pressure sensor and turn the key to on and see if you get pressure
LCMC Member
Old 04-08-2013, 04:17 PM   #13
Yeah hooking up a fuel pressure sensor is a good idea, then you would know if its not getting fuel to the engine. If you are getting fuel then it has to be a spark problem.
Old 04-08-2013, 06:45 PM   #14
TM2189's Avatar
Where can I get a fuel pressure sensor
Old 04-08-2013, 11:00 PM   #15
Tyoung68's Avatar
You can probably barrow one from a autoparts store
Old 04-09-2013, 12:11 AM   #16
Auto zone will rent out tools like tthat
LCMC Member
Old 04-09-2013, 08:31 PM   #17
TM2189's Avatar
I got the fuel sensor and everything checks out. This leads me to believe its a spark plug issue. How would I test the various components responsible for igniting the gas.
Old 04-09-2013, 09:22 PM   #18
Tyoung68's Avatar
Well take a plug wire off stick a screw driver in it and hold it about a 1/4 inch away from the block and see if it sparks of it does then you know it has to be timing and if you dont get a spark make sure you have a good connection to spark plug wire and try again and make sure your not to far away from the block
Old 04-10-2013, 04:40 PM   #19
Probably need a new distributor.
Old 04-10-2013, 04:55 PM   #20
Robbiemustang96's Avatar
You cant change the timing on a coil pack... So most likely its the plugs or the coil pack
Robbiemustang96 is offline   Reply With Quote
Old 04-10-2013, 10:05 PM   #21
TM2189's Avatar
I tested the resistances on my coil pack according to my repair manual and they were all off according to the book. Would this keep the spark plugs from igniting?
Old 04-11-2013, 04:44 PM   #22
Yeah if they are off that means the coil pack is no good, you need a new one. Just buy the oem one from Ford it's more expensive than the aftermarket ones but from what I have heard those aftermarket ones only last around a year anyway.
Old 04-11-2013, 04:46 PM   #23
Project Pony's Avatar
Motorcraft or msd and youll be good. Dont mess with the Bwd brand.
BWD= BIG WASTE of DOUGH!
[SIGPIC][/SIGPIC]
Old 04-11-2013, 04:51 PM   #24
BWD, couldn't of said it better myself.
Old 04-12-2013, 08:43 PM   #25
TM2189's Avatar
I got the new coil pack and I'm still not getting spark. Any suggestions?
Old 04-13-2013, 01:30 PM   #26
BloodRedStang's Avatar
Check your crank and cam position sensors, if they go out completely it can prevent spark. Also, check the sender for your coil pack.
BloodRedStang is offline   Reply With Quote
Old 04-13-2013, 02:54 PM   #27
TM2189's Avatar
You were right, the cam position sensor was loose.
Old 04-13-2013, 03:10 PM   #28
Right on, you get her running?
Old 04-13-2013, 04:04 PM   #29
TM2189's Avatar
No, I have to adjust the timing. Other than that she's fine.
Old 04-13-2013, 10:20 PM   #30
How are you adjusting timing? I didn't think the timing was adjustable on our cars O.o?
Old 04-13-2013, 11:44 PM   #31
TM2189's Avatar
Straight to the timing chain. I'm thinking I knocked it out of sync when I changed my head gaskets.
Old 04-13-2013, 11:54 PM   #32
Tyoung68's Avatar
If it was off you would have a hole in your piston or a busted valve
Old 04-14-2013, 08:09 AM   #33
There shouldn't be any way to be anywhere near close to the timing chain while doing head gaskets unless you took the sprockets and chain off the cam and crank..
If you messed with the lifters or anything, they may need adjusted, and check the wiring on the cam and crank sensors, if the cam sensor was loose, chances are its been compromised and needs replaced.
My biggest suggestion is to get a haynes or helms manual if you don't already have one, they're a life saver.
If you can, get a vid of what the car does when you fire it up now, any sounds or odditys about it.
Old 04-16-2013, 07:36 PM   #34
Any more progress on your engine?
Old 04-16-2013, 07:51 PM   #35
TM2189's Avatar
Not much, school and stuff. But as to what's wrong it looks like the cylinders aren't firing in order. It'll almost start but the engine shake really bad and won't fully start.
02:01 PM
