Check Engine Light - Mustang Evolution
Old 07-29-2003, 11:49 PM   #1
changing the air fliter didnt fix it u probrobly just havent gone through a OBD2 drive cycle yet and stay away form that autozone so called dianostic crap come on all they do is get the code and what it means codes dont tell u what to fix its not that easy lol i wish it was if u get the code i will probrobly be able to help u its kind of hard to fix a car when u dont have access to it so ill do the best i can at assiting u but other than that leave it to a certified ford tech
MUSTANGJUNKY420 is offline   Reply With Quote
Old 07-30-2003, 08:30 AM   #2
Send a message via AIM to el cheapo
allow me to translate
you are completely incompetent and have no buisness messing with your own car. Take it to a ford dealer so they can charge you 3 or 4 times the going rate for the repair.
damn it school, why do you suck so bad??
el cheapo is offline   Reply With Quote
Old 08-01-2003, 07:59 PM   #3
slvr2000stang's Avatar
Otherwise find the correct info on all OBDII codes that come with trouble shooting info.
I believe someone has posted a good link for that on this site.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 08-01-2003, 08:11 PM   #4
Rick0636's Avatar
Even if you don't feel competent to work on your own car, please, go to an independent garage, don't go to a Ford Dealer unless your car is under warranty, they will ream you, I promise you they will.
Old 08-01-2003, 08:59 PM   #5
Send a message via AIM to Rellik Send a message via Yahoo to Rellik
I totally agree with rick, happend to me.
Rellik is offline   Reply With Quote
Old 08-01-2003, 11:38 PM   #6
lol yall crack me up
Old 08-01-2003, 11:41 PM   #7
I am so thrilled to have a critic thanks for your time and energy!!!!!!!!!!!
Old 08-03-2003, 01:27 AM   #8
BlueDonkey's Avatar
If it helps, http://www.obdii.com is OBD-II's site. You can get specifics on their codes et al. there.
BlueDonkey is offline   Reply With Quote
Old 08-03-2003, 08:19 AM   #9
Go to autozone and get the code read for free.
Look online for the codes actual meaing in lay-mans terms, and ask someone what you can do to fix it.
1998 Subaru Legacy L Sedan
New Hottness
1999 V6 5-speed
14.6 @ 95 w/ 2.22 60'
Wrecked
stangin99 is offline   Reply With Quote
Old 08-03-2003, 09:28 AM   #10
Yea, when your at autozone print it out with the error code, and the description, no one ever seems to do that.
Old 08-07-2003, 05:50 PM   #11
Send a message via AIM to mattstang
Check Engine Light
My check engine light came on also. I took it to the Ford Dealership and they found that the DPFE Sensor was bad. They also said when I picked it up that this was a common problem. Also, the Sensor Assembly-EGR Pressure Valve was bad...
All under warranty.
mattstang is offline   Reply With Quote
Old 08-09-2003, 12:29 AM   #12
OR_Red98's Avatar
Region: Oregon
Dennis........Retired USAF, Disabled Vet.
http://www.mustangmods.com/data/666/the_stang_005.jpg
Red "98" coupe V6 AT. Saleen boby kit, 18" replica Saleen rims, FMC "C" springs, Mach 1/Tokico shocks/struts, GT sway bars, GT STB, Sequential turn signals, Euro head lights and clear corners, BBK CAI and GT take-off exhaust.
OR_Red98 is offline   Reply With Quote
check engine
Check Engine Light - Help! Eeyore General Mustang Discussion 15 04-23-2009 07:26 AM
check engine light on! 1999Stang Pre-2005 V6 Mustang 2 08-09-2008 12:04 PM
Need Help with Check Engine light dch61407 1996-2004 Mustang GT 2 01-30-2008 07:01 PM
check engine light avery_y Pre-2005 V6 Mustang 9 01-13-2007 06:16 PM
Check engine light donnie Pre-2005 V6 Mustang 1 05-22-2006 02:53 PM
11:17 PM
