Tailights - Mustang Evolution
Old 04-08-2013, 10:03 PM   #1
Mustangman92's Avatar
Tailights
Front headlight blinks super fast on left and back doesn't work at all right works normally the problem isn't the relay because both of my relays have the same problem
Mustangman92 is offline   Reply With Quote
Old 04-08-2013, 10:04 PM   #2
Robbiemustang96's Avatar
Bad bulbs?!?! Idk lol
Robbiemustang96 is offline   Reply With Quote
Old 04-08-2013, 10:04 PM   #3
1slosix's Avatar
as in back turn signals don't work or any lights out of the back...sounds like the switch
carving corners like a boss
Old 04-08-2013, 10:06 PM   #4
Well they work when I lock the car just not when I is the turn signal
Old 04-08-2013, 10:07 PM   #5
Loose connection maybe?! Or like he said a switch somewhere
Old 04-08-2013, 10:09 PM   #6
Project Pony's Avatar
Kinda sounds like a bad multifunction switch.
[SIGPIC][/SIGPIC]
Old 04-08-2013, 10:10 PM   #7
Idk why that would happen all of sudden and changes in speed with the switch of relays :/ I'm baffled it stopped doing it when I turned the steering wheel a certain way while driving
Old 04-08-2013, 10:17 PM   #8
When I turn the steering wheel slightly to the right it works
Old 04-08-2013, 10:26 PM   #9
1slosix's Avatar
yep that's the switch i was referring too
Old 04-08-2013, 11:33 PM   #10
Is that a difficult fix?
Old 04-08-2013, 11:43 PM   #11
Tyoung68's Avatar
You replace the bulbs? Im pretty sure its jst the bulb happened to my car put a new bulb in and it worked fine
Old 04-09-2013, 01:12 AM   #12
SpeedyG's Avatar
If I'm not mistaken the multifunction switch is located under the steering column
SpeedyG is offline   Reply With Quote
Old 04-09-2013, 06:48 AM   #13
Multifunction switch = wiper/turn signal knob/switch. They cause funky electrical issues when they start to fail. I just replaced one in my explorer. Takes all of 5 minutes to do. If all your bulbs are good and you dont see any obvious wiring issues, it might be worth picking one up cheap at a salvage yard and trying that.
[SIGPIC][/SIGPIC]
Old 04-09-2013, 02:06 PM   #14
Sounds good I may try that because I just put in new sequential tails with new wiring harnesses recently and the lights are def. working and the wiring by the relay seems intact so it must be the switch
Old 04-09-2013, 03:01 PM   #15
Both work perfectly when the emergency lights are on
Old 04-09-2013, 03:12 PM   #16
Actually it clicks normal but the left one still doesn't work.
Old 04-09-2013, 03:58 PM   #17
Sounding more like the multifunction switch.
[SIGPIC][/SIGPIC]
Old 04-09-2013, 07:50 PM   #18
Do the emergency lights run in with the multi fuction switch?
Old 04-09-2013, 08:01 PM   #19
samuelsmith's Avatar
blinker fluid jj
Old 04-09-2013, 08:06 PM   #20
Wtf is blinker fluid?
Old 04-09-2013, 08:07 PM   #21
They can.
[SIGPIC][/SIGPIC]
Old 04-09-2013, 08:08 PM   #22
I hope that was a joke ha but idk if I should check on the left taillight wiring or not and where can I find a multifunction switch for a reasonable price online no junk yards around here have mustangs
Old 04-09-2013, 08:09 PM   #23
Tyoung68's Avatar
It adds at least 10hp
---------- Post added at 07:09 PM ---------- Previous post was at 07:08 PM ----------
It lower the resistance in your wires so it flows smoother
Old 04-09-2013, 08:31 PM   #24
Sounds legit... Maybe I should get a v tech sticker while I'm at it I heard those at like 40-50hp
Old 04-09-2013, 08:36 PM   #25
Check your wiring first, use a multimeter amd test the leads.
Then check prices at rockauto.com.
Local autopart stores will have em from between 50-75 bucks usually. Dont buy the bwd garbage or any of the cheapy store brand ones, always spend the few extra bucks and get oem replacements even more so when dealing with electronics.
[SIGPIC][/SIGPIC]
Old 04-09-2013, 08:57 PM   #26
Something you send your girlfriend in the parts store for. If she can not take a joke do not tell her.
08:44 PM
