U-Joint problem??? - Mustang Evolution
Old 04-10-2013, 05:12 PM   #1
TheHulk99's Avatar
U-Joint problem???
Hey guys, I just started hearing a really annoying ticking sound when coasting and coming to a stop. it sounds like a bicycle with a card in the spokes... really annoying. any ideas?
TheHulk99 is offline   Reply With Quote
Old 04-10-2013, 06:27 PM   #2
brooksyx's Avatar
Crack in your exhaust manifold? Min has it when the car starts cold but goes away.
brooksyx is offline   Reply With Quote
Old 04-10-2013, 11:57 PM   #3
twotone01's Avatar
Both manis have been replaced
twotone01 is offline   Reply With Quote
Old 04-11-2013, 12:14 AM   #4
BloodRedStang's Avatar
Did you reroute the ac drip line when the manifolds were replaced? If not chances are good that the mani under the drip tube is cracked again
BloodRedStang is offline   Reply With Quote
Old 04-11-2013, 12:35 AM   #5
TheHulk99's Avatar
it's definitely not the manifolds... haha
---------- Post added at 10:35 PM ---------- Previous post was at 10:34 PM ----------
it's not a sputtering sound like if the manis were cracked, it's a tick coming from somewhere up front or beneath the front seats it sounds like. I don't really know what it could be
Old 04-11-2013, 06:24 AM   #6
your car a 5 speed?
Old 04-11-2013, 09:20 AM   #7
TheHulk99's Avatar
your car a 5 speed?
yeah it is
---------- Post added at 07:20 AM ---------- Previous post was at 07:19 AM ----------
your car a 5 speed?
yes it is
Old 04-11-2013, 09:40 AM   #8
yeah it is
yes it is
Id be looking at a pilot bushing or input shaft bearing as the culprit. Does the sound change depending on how much you have the clutch pedal down? and does it do it in between gears?
Old 04-11-2013, 09:46 AM   #9
TheHulk99's Avatar
no it doesn't change depending on how much the clutch pedal is down.... and not in between gears. only when I'm coasting.. and when Im coasting and slowing down the tick gets slower..
Old 04-11-2013, 10:10 AM   #10
Sounds like input shaft bearing possibly, may even be a cracked flywheel.
My 95 has some odd noises surrounding the clutch, I had a weird ticking/rattling going on that sounded a lot like what you're describing so I pulled the clutch fork dust cover off and moved the clutch fork around, did wonders to eliminate the rattle, not I just have the tell tale throwout bearing squeak.. id drop the trans and inspect everything between the motor and trans
Old 04-11-2013, 10:16 AM   #11
Tyoung68's Avatar
All you have to do is crawl under your car and try to turn your drive shaft and if it has a lot of play then you need new u-joints
11:33 AM
