P0455 - Mustang Evolution
Old 04-11-2013, 07:11 PM   #1
jleber123's Avatar
P0455
Welp, I need help with this. Idk how to check or where to check. AND NO IT'S NOT THE GAS CAP. It would clearly say loose gas cap lol. I'm just not understand "gross leak/no flow" that's also throwing me off
jleber123 is offline   Reply With Quote
Old 04-11-2013, 07:18 PM   #2
Torchredfrankie's Avatar
Maybe a gas leak check under your car. Dose it smell like gas while you drive it?
Torchredfrankie is offline   Reply With Quote
Old 04-11-2013, 07:20 PM   #3
jleber123's Avatar
No gas leak, ruled that one out. My engine is too damn noisey to hear any vacuum sound uner the car to see if I have any leaks
Old 04-11-2013, 07:27 PM   #4
Check the rubber or ring on the inner lip of the gas cap if it is all cracked then yes replace it. If it look good then I doubt it is the gas cap unless you did not get it on tight enough last time you filled. However that code is related to a large EVAP leak which i can assure you is NOT the gas cap. This is most likely a faulty Canister Purge Solenoid (most common problem) However there are also a few other things it could be and it is best left to be diagnose by someone who can check these items for function. But before you take it in check all the EVAP line under the hood and by the fuel tank. And not just looking at them touch them and move them sometime they can be cracked and not seen until moved around check all vacuum lines.
Old 04-11-2013, 07:32 PM   #5
jleber123's Avatar
Ugh f*ck knew this was gonna be a problem
04:26 PM
