Under the hood - Mustang Evolution
Old 04-13-2013, 10:42 AM   #1
Torchredfrankie's Avatar
Under the hood
So my sis wants to take my stang to her high school car show, I want to give the engine some detail any one got some ideas? I was thinking putting in a strut bar. I'm getting caster camber plates because I lowered it and also it gives a nice touch. Pics of engine bays are welcome thanks!
Torchredfrankie is offline   Reply With Quote
Old 04-13-2013, 01:30 PM   #2
Crowned1's Avatar
a painted front strut bar would be a nice touch! Try and search Engine Dress up for your year and see what comes up! Love to see some pics afterwards!
Crowned1 is offline   Reply With Quote
Old 04-13-2013, 03:33 PM   #3
Yea that what I was thinking, just finished doing the front ball joints got rid of that gap in the front I got from my H&Rs love the stances
Old 04-13-2013, 07:15 PM   #4
Also want to pressure wash the engine but kinda scared of doing it, any tips???
---------- Post added at 07:15 PM ---------- Previous post was at 07:15 PM ----------
Also want to pressure wash the engine but kinda scared of doing it, any tips????
Old 04-13-2013, 07:25 PM   #5
Project Pony's Avatar
Let it sit and dry in the hot son for several hours after spraying the engine bay. Also cover the coil pack and other importants.
Water will sit in the spark plugs wells and usually cause misfires. Just leave ot with the hood popped in the su all day and you should be good.
Really its best to not use a pressure washer on the engine, but do it by hand.
[SIGPIC][/SIGPIC]
Old 04-13-2013, 09:50 PM   #6
1slosix's Avatar
i pop my hood at every meet i go to...i keep turtle wax f21 in my trunk just to wipe the engine down beforehand..
carving corners like a boss
Old 04-13-2013, 09:57 PM   #7
Sluder4's Avatar
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 04-13-2013, 09:58 PM   #8
Sluder4's Avatar
New CAI looks pretty good sorry ment to post just once :/
Old 04-13-2013, 10:00 PM   #9
Can I get away with a 275 50 17 on stock bullits? Or will I rub? There for the rear?
Old 04-13-2013, 10:00 PM   #10
1slosix's Avatar
stick to a 275/40/17 or you'll mess with your speedo
Old 04-13-2013, 10:06 PM   #11
Joey2000srs's Avatar
How did you clean your engine bay?? I've been trying tons of methods, none seem to be working :/
Joey2000srs is offline   Reply With Quote
Old 04-13-2013, 10:07 PM   #12
1slosix's Avatar
believe it or not that pic was taken after i hand wiped down every inch with a foam brush, microfibers, and a bottle of mequiars detail spray..then used turtle wax f21 on the hoses
granted when i really detail it i use purple power and a hose lol
Old 04-13-2013, 10:09 PM   #13
Will it look funny because I have 235/50/17 in the front?
Old 04-13-2013, 10:10 PM   #14
1slosix's Avatar
good god why are you running 05+ tires on your fronts? pics of this setup
Old 04-13-2013, 10:21 PM   #15
It's dark out but yea I have that in the front is that bad?
Old 04-13-2013, 10:25 PM   #16
1slosix's Avatar
well it's not an optimal tire for our cars...do you have any pics at all?
Old 04-13-2013, 10:29 PM   #17
I can take a pic of the tire?
Old 04-13-2013, 10:31 PM   #18
Old 04-13-2013, 10:32 PM   #19
Old 04-13-2013, 11:43 PM   #20
1slosix's Avatar
yeah i can tell the tire is a bit stretched...but that's to be expected since you're running a skinnier tire on that wheel then it does from factory. unless those are off of an 05+ then that's their size from factory but still aren't as wide as they should be on your GT stock
Old 04-14-2013, 01:24 AM   #21
Yea They came with 235/55/17 dose that mean the rim is wider? I think the rim is from 05+
Old 04-14-2013, 08:21 AM   #22
98mustang11's Avatar
What size tire you need to run on bullits? My front two are the silver bullits which are off the 05+ and my backs are black bullits... I'm running the 235/55/17 all the way around right now cause I didn't have another set of tires and I took em off the 05 gt rims I had the backs are 17/9 fronts are 17/8
---------- Post added at 09:21 AM ---------- Previous post was at 09:20 AM ----------
Is 255/40/17 right?
98mustang11 is offline   Reply With Quote
Old 04-14-2013, 09:37 AM   #23
I'm seat I'm going to run a 275/45/17 in the back and a 275/40/17 in the front
Old 04-14-2013, 10:59 AM   #24
andregayola's Avatar
Well i think your tire shouldn't be skinnier than you rim it causes issues when u park and you mess up your rims
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 04-14-2013, 11:40 AM   #25
XSlashDashX's Avatar
Haha, I need to clean my engine bay as well. Dirty!
Old 04-14-2013, 11:52 AM   #26
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
I don't allow my engine to accumulate too much dust. I wipe it down after every wash.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 04-14-2013, 03:01 PM   #27
Ghostedmind's Avatar
I've got many, many, many years of dirt dust and road grime to get off my engine, the owner before m never cleaned the engine bay
LCMC Member
Old 04-14-2013, 03:18 PM   #28
1slosix's Avatar
Id run a 245/45/17 and a 274/40/17 op
Old 04-14-2013, 05:15 PM   #29
Mustang81596's Avatar
I'm on the same boat as you.. Do you know how to get rid of really bad corrosion?
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 04-14-2013, 05:25 PM   #30
1slosix's Avatar
neverdull
Old 04-14-2013, 05:27 PM   #31
neverdull
I have about 2 cans in my shed, will it clean right up? I mean, it's BAD.
Old 04-14-2013, 05:54 PM   #32
the only things I've ever heard of are things like coke~cola, PB blaster things like that. I haven't noticed any corrosion on my engine, but I dont think I've ever actually gotten to the metal yet, last time I tried to clean it up with that Gunk brand gel crap I didn't notice any change at all really. i need something better...that won't mess up my engine. then as I take parts off I'm going to start coating it with some paint and clear so it will never be that hard to clean again
LCMC Member
07:57 PM
