check engine light after x pipe installed - Mustang Evolution
Old 04-17-2013, 10:46 AM   #1
hepler02's Avatar
So about a day and a half after I had a new exhaust put in my check engine light is on. ( pypes x pipe with high flow cats)The car is running much better than before but just wondering if anyone has experienced this. I read that I should unplug the 02 sensors but Ive only read it for people who have no cats and I do. So not sure if that would apply to me as well. Any ideas?
hepler02 is offline   Reply With Quote
Old 04-17-2013, 10:50 AM   #2
MidnightBlueGT's Avatar
Is it a shorty with lts? Or a regular catted x?
Old 04-17-2013, 10:52 AM   #3
1slosix's Avatar
if you just unplug the rear o2's it won't make any difference you'll still get a code...you'll either have to
a- get mil eliminators
b- try some spark plug non foulers
c- buy a tune
believe it or not you can throw the same codes a catless system would even with high flows
carving corners like a boss
Old 04-17-2013, 10:52 AM   #4
1slosix's Avatar
c- buy a tune
Old 04-17-2013, 10:54 AM   #5
Project Pony's Avatar
What code is coming up? That will really help to know, post it here and we can help you better.
Hell it could even just be a coincidence, or not. Get the codes read at your local auto parts store if you dont have a scanner.
[SIGPIC][/SIGPIC]
Old 04-17-2013, 10:55 AM   #6
He beat me to my second response. I was going to suggest mil's.
Old 04-17-2013, 11:10 AM   #7
StangReaper's Avatar
A custom tune does the trick really well! Plug it in and boom cleared.
StangReaper is offline   Reply With Quote
Old 04-17-2013, 11:13 AM   #8
hepler02's Avatar
Im gonna post up the codes later on today
Old 04-17-2013, 05:37 PM   #9
hepler02's Avatar
P1285
Old 04-17-2013, 05:51 PM   #10
Cylinder head overheat detected. It may or may not be related to you getting the exhaust done. No other codes?
---------- Post added at 07:51 PM ---------- Previous post was at 07:49 PM ----------
Pulled this from modded mustang. Good list of possibilities and things to check.
"Code*P1285*is*Cylinder*head*overheat sensed: if you have one of those do it your self code readers, they have generic code discriptions, some Vehicle manifactures may use different code discriptions there for gives you wrong data..this code will come on for a few posible reasons
1.Low engine coolant level
2.Engine problems and actualy overheating, lack of oil flow, oil pump, restricted*oil*filter, cooler etc,
3.engine cooling system problems, thermostat, restricted*radiator, electric fans not working, etc
4. bad coolant temp senor or wiring, too a bad PCM, got to start trouble shooting..."
[SIGPIC][/SIGPIC]
Old 04-17-2013, 06:06 PM   #11
hepler02's Avatar
Yeah Im deff going to look further into it. I havent had any issues with overheating or high temps..I have noticed recently the heat takes a bit longer to go on or it will start to go on but then get cool again not sure if maybe its something with the radiator..hmm
Old 04-17-2013, 06:23 PM   #12
Cold be. Pull the thermostat and boil it, seen when or if it pops open. Thats free so good place to start. Is there moisture around the weep hole of the water pump?
[SIGPIC][/SIGPIC]
Old 05-13-2013, 07:13 AM   #13
hepler02's Avatar
So the car did overheat but it turns out that was caused by the thermostat
Old 05-13-2013, 07:40 AM   #14
hepler02's Avatar
Oh nd my check engine light is still on Im gonna see if Im still getting the same code
check engine
» Members Mustangs
Mustang
cynthia
Sal
KSN95
Add your Mustang
11:00 AM
