PATS for dummies translation - Mustang Evolution
Old 04-18-2013, 07:13 PM   #1
samuelsmith's Avatar
419-01-1 Anti-Theft — PATS
DIAGNOSIS AND TESTING
Passive Anti-Theft System (PATS) — Pinpoint Tests
PINPOINT TEST A: NO COMMUNICATION WITH THE INSTRUMENT CLUSTER
Test Step Result / Action to Take A1 CHECK THE BATTERY POWER SUPPLY TO THE INSTRUMENT CLUSTER • Key in OFF position. • Disconnect: Instrument Cluster C220b. • Measure voltage between instrument cluster C220b Pin 10, Circuit 729 (RD/WH), harness side and ground.
Yes GO to A2. No REPAIR the circuit. REPEAT the self-test. • Is the voltage greater than 10 volts? CLEAR the DTCs. A2 CHECK THE RUN POWER SUPPLY TO THE INSTRUMENT CLUSTER • Key in ON position. • Measure the voltage between instrument cluster C220b Pin 11, Circuit 489 (PK/BK), harness side and ground.
Yes GO to A3. No REPAIR the circuit. REPEAT the self-test. • Is the voltage greater than 10 volts? CLEAR the DTCs. (Continued)
Copyright  2002, Ford Motor Company Last updated: 5/14/2003 2003 Mustang, 8/2002
419-01-2 419-01-2 Anti-Theft — PATS
DIAGNOSIS AND TESTING (Continued)
PINPOINT TEST A: NO COMMUNICATION WITH THE INSTRUMENT CLUSTER (Continued)
Test Step Result / Action to Take A3 CHECK RUN/START POWER SUPPLY TO THE INSTRUMENT CLUSTER • Measure the voltage between the instrument cluster C220b Pin 12, Circuit 20 (WH/LB), harness side and ground.
Yes GO to A4. No REPAIR Circuit 20 (WH/LB). REPEAT the • Is the voltage greater than 10 volts? self-test. CLEAR the DTCs. A4 CHECK GROUND CIRCUIT 397 (BK/WH) FOR AN OPEN • Key in OFF position. • Measure the resistance between instrument cluster C220b Pin 20, Circuit 397 (BK/WH), harness side and ground.
Yes GO to A5. No REPAIR the circuit. REPEAT the self-test. • Is the resistance less than 5 ohms? CLEAR the DTCs. A5 CHECK GROUND CIRCUIT 1205 (BK) FOR OPEN • Measure the resistance between instrument cluster C220b Pin 1, Circuit 1205 (BK), harness side and ground.
Yes REFER to Section 418-00. No REPAIR the circuit. REPEAT the self-test. • Is the resistance less than 5 ohms? CLEAR the DTCs.
419-01-3 419-01-3 Anti-Theft — PATS
PINPOINT TEST B: THE ANTI-THEFT INDICATOR IS ALWAYS/NEVER ON — NO THREE SECOND THEFT INDICATOR PROVE OUT
Test Step Result / Action to Take B1 ENTER THE INSTRUMENT CLUSTER ACTIVE COMMAND MODE • Key in OFF position. Yes• Connect the diagnostic tool. GO to B2.• Enter the instrument cluster active command mode. • Can the instrument cluster active command mode be No entered? GO to Pinpoint Test A. B2 TRIGGER THE ANTI-THEFT INDICATOR • Trigger the instrument cluster active command WARNING Yes LAMPS AND CHIME to ON. The anti-theft indicator is OK. VERIFY the • Does the anti-theft indicator illuminate? concern with the customer. No GO to B3. B3 CHECK THE ANTI-THEFT INDICATOR • Key in OFF position. • Disconnect: Anti-Theft LED. • Measure the resistance between the pins of the anti-theft LED in both directions.
Yes INSTALL a new instrument cluster; for additional information, REFER to Section 413-01. CYCLE the ignition to RUN using two encoded ignition keys. GO to Pinpoint Test J to initialize the module. REPEAT the self-test. CLEAR the DTCs. No INSTALL a new anti-theft LED. For additional information, REFER to Section • Is the resistance greater than 10,000 ohms in one direction, 413-01. REPEAT the self-test. CLEAR the and 10-20 ohms in the other direction? DTCs.
PINPOINT TEST C: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — THE VEHICLE STARTS BUT FLASHES A FAULT CODE ON THE THEFT INDICATOR AT KEY ON
Test Step Result / Action to Take C1 CHECK THE ANTI-THEFT INDICATOR FOR CORRECT OPERATION • Key in START position. Yes • Verify the theft indicator proves out correctly. If the vehicle starts, VERIFY correct PCM • Does the vehicle start once the theft proves out? calibration for vehicle. REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual Section 3. No GO to C2. C2 CHECK THE PCM DIAGNOSTIC CAPABILITY • Connect the diagnostic tool. • Retrieve and document continuous DTCs. • Enter the following diagnostic mode on the diagnostic tool: Clear YesContinuous DTCs. GO to C3.• Enter the following diagnostic mode on the diagnostic tool: PCM Self-Test. No • Does diagnostic tool communicate with the PCM? REFER to Section 418-00. (Continued)
419-01-4 419-01-4 Anti-Theft — PATS
PINPOINT TEST C: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — THE VEHICLE STARTS BUT FLASHES A FAULT CODE ON THE THEFT INDICATOR AT KEY ON (Continued)
Test Step Result / Action to Take C3 RETRIEVE THE PCM DTCS • Retrieve and document continuous DTCs. Yes • Is DTC P1260 recorded? GO to C4. No VERIFY PCM power and ground. REFER to Powertrain Control/Emissions Diagnosis (PC/ED) manual Section 3. C4 CHECK THE COMMUNICATION NETWORK • Repeat Inspection and Verification steps 3 through 7; refer to Yes Inspection and Verification. INSTALL a new instrument cluster; for • Key in OFF position. additional information, REFER to Section • Retrieve and document continuous DTCs. 413-01. CYCLE the ignition to RUN using • Enter the following diagnostic mode on the diagnostic tool: Clear two encoded ignition keys. GO to Pinpoint Continuous DTCs. Test J to initialize the module. REPEAT • Enter the following diagnostic mode on the diagnostic tool: the self-test. CLEAR the DTCs. If DTC Instrument Cluster On-Demand Self-Test. U1147 is still present, INSTALL a new • Is DTC U1147 retrieved? PCM; for additional information, REFER to Section 303-14. TEST the system for normal operation. (You must follow Pinpoint Test J to initialize module.) No System is OK.
PINPOINT TEST D: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — ANTI-THEFT NUMBER OF PROGRAMMED KEYS IS BELOW MINIMUM
Test Step Result / Action to Take D1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF-TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. GO to D2. • Is DTC B1213 the only DTC retrieved? No REPAIR the other DTCs retrieved. REPEAT the Instrument Cluster On-Demand Self-Test. CLEAR the DTCs. D2 CHECK FOR PROGRAMMED ENCODED IGNITION KEYS — MONITOR THE INSTRUMENT CLUSTER PID NUMKEYS • Monitor the instrument cluster PID NUMKEYS. Yes • Does the instrument cluster PID NUMKEYS display less GO to D3. than two encoded ignition keys programmed? No System is OK. D3 PROGRAM ENCODED IGNITION KEYS • NOTE: Two programmed encoded ignition keys must be Yes available to start the vehicle. CLEAR the DTCs. CARRY OUT the Instrument Cluster On-Demand Self-TestCut a new encoded ignition key. to verify all codes have been cleared.• Key in ON position. REPEAT the self-test. CLEAR the DTCs.• Program the new encoded ignition key. • Does the theft indicator illuminate for three seconds, and No then go out? If the theft indicator is on continuously, REPEAT TEST STEP D3 with a second new encoded ignition key. If the theft indicator is flashing, RETRIEVE DTCs stored for the new fault and REPAIR the other DTC(s) retrieved.
PINPOINT TEST E: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — ANTENNA NOT CONNECTED OR DEFECTIVE TRANSCEIVER
Test Step Result / Action to Take E1 INSPECT THE PATS TRANSCEIVER FOR CORRECT INSTALLATION • Key in OFF position. (Continued)
419-01-5 419-01-5 Anti-Theft — PATS
PINPOINT TEST E: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — ANTENNA NOT CONNECTED OR DEFECTIVE TRANSCEIVER (Continued)
Test Step Result / Action to Take E1 INSPECT THE PATS TRANSCEIVER FOR CORRECT INSTALLATION (Continued)
• Verify the PATS transceiver is correctly installed; refer to YesModule—Passive Anti-Theft Transceiver . INSTALL a new PATS transceiver module;• Connect the diagnostic tool. for additional information, REFER to• Enter the following diagnostic mode on the diagnostic tool: Module—Passive Anti-Theft Transceiver.Instrument Cluster On-Demand Self-Test. REPEAT the Instrument Cluster• Retrieve and document continuous DTCs. On-Demand Self-Test. CLEAR the DTCs.• Enter the following diagnostic mode on the diagnostic tool: Clear Continuous DTCs. No • Is DTC B1232 or B2103 retrieved? System is OK.
PINPOINT TEST F: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS IGNITION KEY TRANSPONDER SIGNAL IS NOT RECEIVED (DAMAGED KEY OR NON-PATS KEY)
NOTE: Large metallic objects, electronic debit transponder devices or a second key on the same key ring as the PATS ignition key may cause vehicle starting problems and record DTCs under certain conditions. If a fault cannot be identified, examine the customer’s key for such objects or devices. If present, inform the customer that they need to keep these objects from touching the PATS ignition key while starting the engine. These objects and devices cannot damage the PATS ignition key, but can cause a momentary problem if they are too close to the key during engine start. If a problem occurs, turn ignition OFF and restart the engine with all other objects on the key ring held away from the ignition key. Check to ensure the encoded ignition key used by the customer is an approved Ford encoded ignition key (encoded ignition keys from Rotunda, Ilco, Curtis, or Strattec are approved Ford encoded ignition keys). Test Step Result / Action to Take F1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF-TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. GO to F2. • Is DTC B1600 retrieved? No If other DTCs are retrieved, REFER to Instrument Cluster Diagnostic Trouble Code (DTC) Index. If no DTCs are retrieved, system is OK. F2 PROGRAM A NEW ENCODED IGNITION KEY • Key in OFF position. • NOTE: Check to make sure the customer and replacement encoded ignition keys are approved Ford encoded PATS ignition keys. Unapproved PATS keys do not always operate correctly over different temperature ranges (encoded ignition keys from Rotunda, Ilco, or Strattec are approved encoded ignition keys). Yes Cut a new encoded ignition key. GO to F3. • Key in ON position. No• Program the new encoded ignition key; for additional If no other DTCs are retrieved, system isinformation, refer to Key Programming—Erase All Key Codes OK.and Program Two Keys. • Enter the following diagnostic mode on the diagnostic tool: If other DTCs are retrieved, REFER to Instrument Cluster On-Demand Self-Test. Instrument Cluster Diagnostic Trouble • Is DTC B1600 still present? Code (DTC) Index. F3 INSTALL A NEW PATS TRANSCEIVER • Key in OFF position. Yes • Install a new PATS transceiver; for additional information, refer INSTALL a new instrument cluster; for to Module—Passive Anti-Theft Transceiver. additional information, REFER to Section • Key in ON position. 413-01. CYCLE the ignition to RUN using two encoded ignition keys. GO to PinpointNOTE: Use the customer’s original encoded ignition key, not the Test J to initialize the module. REPEATencoded ignition key that was cut in the previous step. the self-test. CLEAR the DTCs.• Enter the following diagnostic mode on the diagnostic tool: Instrument Cluster On-Demand Self-Test. No • Is DTC B1600 retrieved? System is OK.
419-01-6 419-01-6 Anti-Theft — PATS
PINPOINT TEST G: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS RECEIVED INCORRECT KEY-CODE FROM IGNITION KEY TRANSPONDER (UNPROGRAMMED ENCODED IGNITION KEY)
NOTE: Large metallic objects, electronic debit transponder devices or a second key on the same key ring as the PATS ignition key may cause vehicle starting problems and record DTCs under certain conditions. If a fault cannot be identified, examine the customer’s key for such objects or devices. If present, inform the customer that they need to keep these objects from touching the PATS ignition key while starting the engine. These objects and devices cannot damage the PATS ignition key, but can cause a momentary problem if they are too close to the key during engine start. If a problem occurs, turn ignition OFF and restart the engine with all other objects on the key ring held away from the ignition key. Check to ensure the encoded ignition key used by the customer is an approved Ford encoded ignition key (encoded ignition keys from Rotunda, Ilco, Curtis, or Strattec are approved Ford encoded ignition keys). Test Step Result / Action to Take G1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. GO to G2. • Is DTC B1601 recorded? No System is OK. CHECK all customer encoded ignition keys with Instrument Cluster On-Demand Self-Test to verify all other encoded ignition keys are programmed. G2 CHECK FOR PROGRAMMED ENCODED IGNITION KEYS — MONITOR THE INSTRUMENT CLUSTER PID NUMKEYS • Monitor the instrument cluster PID NUMKEYS. Yes • Does the instrument cluster PID NUMKEYS display 8? ERASE and REPROGRAM the key codes; for additional information, REFER to Key Programming—Erase All Key Codes and Program Two Keys. REPEAT the self-test. CLEAR the DTCs. No GO to G3. G3 CHECK THE NUMBER OF PROGRAMMED ENCODED IGNITION KEYS AVAILABLE • Verify there are at least two currently programmed encoded Yes ignition keys available with the vehicle. GO to G4. • Are at least two currently programmed encoded ignition No keys available with the vehicle? CUT a new encoded ignition keys so that at least two encoded ignition keys are available. PROGRAM the encoded ignition keys; Key Programming—Erase All Key Codes and Program Two Keys. GO to G4. G4 VERIFY THE INSTRUMENT CLUSTER PID SPARE KY INDICATES ENABLE • Monitor the instrument cluster PID SPARE KY. Yes • Does the instrument cluster PID SPARE KY indicate REFER to Key Programming—Erase All ENABLE? Key Codes and Program Two Keys. CLEAR the DTCs, REPEAT the self-testGO to G5. No REFER to Key Programming—Enable/Disable Spare Key Programming to enable the PID SPARE KEY to ENABLE. TEST the system for normal operation. Once completed, GO to G5. (Continued)
419-01-7 419-01-7 Anti-Theft — PATS
PINPOINT TEST G: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS RECEIVED INCORRECT KEY-CODE FROM IGNITION KEY TRANSPONDER (UNPROGRAMMED ENCODED IGNITION KEY) (Continued)
Test Step Result / Action to Take G5 CHECK THE ENCODED IGNITION KEYS FOR CORRECT OPERATION • Key in OFF position. Yes • Key in ON position. System is OK. If there are additional keys that need to be programmed, for additionalStart the vehicle using the first encoded ignition key. information, REFER to Key• Key in ON position. Programming—Program a Key Using TwoStart the vehicle with the second ignition key. Programmed Keys.• Key in OFF position. • Does the vehicle start correctly using both encoded ignition No keys? GO to G6. G6 RETRIEVE THE INSTRUMENT CLUSTER DTCS — CHECK FOR DTC B1601 • Retrieve and document continuous DTCs. Yes • Enter the following diagnostic mode on the diagnostic tool: Clear INSTALL a new instrument cluster; for Continuous DTCs. additional information, REFER to Section • Carry out a instrument cluster self-test using both ignition keys 413-01. CYCLE the ignition to RUN using from Step G5. two encoded ignition keys. GO to Pinpoint • Is DTC B1601 retrieved? Test J to initialize the vehicle. REPEAT the self-test. CLEAR the DTCs. No System is OK. If other DTCs are retrieved, REFER to Instrument Cluster Module Diagnostic Trouble Code (DTC) Index.
PINPOINT TEST H: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS RECEIVED INVALID FORMAT OF KEY-CODE FROM IGNITION KEY TRANSPONDER (PARTIAL KEY READ)
NOTE: Large metallic objects, electronic debit transponder devices or a second key on the same key ring as the PATS ignition key may cause vehicle starting problems and record DTCs under certain conditions. If a fault cannot be identified, examine the customer’s key for such objects or devices. If present, inform the customer that they need to keep these objects from touching the PATS ignition key while starting the engine. These objects and devices cannot damage the PATS ignition key, but can cause a momentary problem if they are too close to the key during engine start. If a problem occurs, turn ignition OFF and restart the engine with all other objects on the key ring held away from the ignition key. Check to ensure the encoded ignition key used by the customer is an approved Ford encoded ignition key (encoded ignition keys from Rotunda, Ilco, Curtis, or Strattec are approved Ford encoded ignition keys). Test Step Result / Action to Take H1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. GO to H2. • Is DTC B1602 retrieved? No System is OK. CHECK all customer encoded ignition keys with Instrument Cluster On-Demand Self-Test to verify all other keys are programmed. H2 OBTAIN A NEW ENCODED IGNITION KEY • Key in OFF position. Yes • Cut a new encoded ignition key. GO to H3. • Key in ON position. No • Program a new encoded ignition key; for additional information, System is OK. If the customer has any refer to Key Programming—Erase All Key Codes and Program remaining encoded keys at home, instruct Two Keys. them to carry out Key • Enter the following diagnostic mode on the diagnostic tool: Programming—Program a Key Using Two Instrument Cluster On-Demand Self-Test. Programmed Keys on each remaining key. • Is DTC B1602 retrieved? This procedure is detailed in the Owners Guide. (Continued)
419-01-8 419-01-8 Anti-Theft — PATS
PINPOINT TEST H: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS RECEIVED INVALID FORMAT OF KEY-CODE FROM IGNITION KEY TRANSPONDER (PARTIAL KEY READ) (Continued)
Test Step Result / Action to Take H3 INSTALL A NEW PATS TRANSCEIVER • Key in OFF position. • Install a new PATS transceiver; for additional information, refer Yesto Module—Passive Anti-Theft Transceiver. REFER to Instrument Cluster Diagnostic• Key in ON position. Trouble Code (DTC) Index.• Enter the following diagnostic mode on the diagnostic tool: Instrument Cluster On-Demand Self-Test. No • Are any DTCs retrieved? System is OK.
PINPOINT TEST I: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS TRANSCEIVER SIGNAL IS NOT RECEIVED (NOT CONNECTED, DAMAGED, OR WIRING)
Test Step Result / Action to Take I1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. GO to I2. • Is DTC B1681 retrieved? No System is OK. I2 CHECK THE PATS TRANSCEIVER FOR VOLTAGE — CIRCUIT 20 (WH/LB) • Key in OFF position. • Disconnect: PATS Transceiver C252. • Key in ON position. • Measure the voltage between PATS transceiver C252 Pin 2, Circuit 20 (WH/LB), harness side and ground.
Yes GO to I3. No REPAIR Circuit 20 (WH/LB). REPEAT the • Is the voltage greater than 9 volts? self-test. CLEAR the DTCs. I3 CHECK THE PATS TRANSCEIVER GROUND — CIRCUIT 397 (BK/WH) • Key in OFF position. (Continued)
419-01-9 419-01-9 Anti-Theft — PATS
PINPOINT TEST I: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PATS TRANSCEIVER SIGNAL IS NOT RECEIVED (NOT CONNECTED, DAMAGED, OR WIRING) (Continued)
Test Step Result / Action to Take I3 CHECK THE PATS TRANSCEIVER GROUND — CIRCUIT 397 (BK/WH) (Continued)
• Measure the resistance between PATS transceiver C252 Pin 1, Circuit 397 (BK/WH), harness side and ground.
Yes GO to I4. No REPAIR Circuit 397 (BK/WH). REPEAT • Is the resistance less than 5 ohms? the self-test. CLEAR the DTCs. I4 CHECK THE PATS TRANSCEIVER RECEIVE CIRCUIT FOR VOLTAGE — CIRCUIT 1216 (GY/OG) • Connect: PATS Transceiver C252. • Key in ON position. • Measure the voltage by back probing between PATS transceiver C252 Pin 3, Circuit 1216 (GY/OG), harness side and ground.
Yes GO to I6. No • Is the voltage greater than 9 volts? GO to I5. I5 CHECK THE PATS TRANSCEIVER RECEIVE CIRCUIT FOR SHORT TO GROUND — CIRCUIT 1216 (GY/OG) • Key in OFF position. • Disconnect: PATS Transceiver C252.
(Continued)
419-01-10 419-01-10 Anti-Theft — PATS
Test Step Result / Action to Take I5 CHECK THE PATS TRANSCEIVER RECEIVE CIRCUIT FOR SHORT TO GROUND — CIRCUIT 1216 (GY/OG) (Continued)
• Measure the resistance between PATS transceiver C252 Pin 3, Circuit 1216 (GY/OG), harness side and ground.
Yes GO to I6. No CHECK Circuit 1216 (GY/OG) for short to ground. If the circuit is OK, INSTALL a new instrument cluster; for additional information, REFER to Section 413-01. CYCLE the ignition key to RUN using two encoded ignition keys. GO to Pinpoint Test J to initialize the module. REPEAT the self-test. CLEAR the DTCs. If the circuit is not OK, REPAIR Circuit 1216 (GY/OG). CLEAR the DTCs. TEST the system for • Is the resistance greater than 100 ohms? normal operation. I6 CHECK CIRCUIT 1216 (GY/OG) FOR OPEN • Key in OFF position. • Disconnect: PATS Transceiver C252. • Disconnect: Instrument Cluster C220a. • Measure the resistance between PATS transceiver C252 Pin 3, Circuit 1216 (GY/OG), harness side and instrument cluster C220a Pin 7, Circuit 1216 (GY/OG), harness side.
Yes GO to I7. No REPAIR Circuit 1216 (GY/OG). CLEAR the DTCs. TEST the system for normal • Is the resistance less than 5 ohms? operation. I7 CHECK THE PATS TRANSCEIVER TRANSMIT CIRCUIT FOR VOLTAGE — CIRCUIT 1215 (WH/LG) • Key in OFF position. • Connect: PATS Transceiver C252. • Connect: Instrument Cluster C220a. • Key in ON position. (Continued)
419-01-11 419-01-11 Anti-Theft — PATS
Test Step Result / Action to Take I7 CHECK THE PATS TRANSCEIVER TRANSMIT CIRCUIT FOR VOLTAGE — CIRCUIT 1215 (WH/LG) (Continued)
• Measure the voltage by back probing between PATS transceiver C252 Pin 4, Circuit 1215 (WH/LG), harness side and ground.
Yes GO to I9. No • Is the voltage greater than 9 volts? GO to I8. I8 CHECK THE PATS TRANSCEIVER TRANSMIT CIRCUIT FOR OPEN — CIRCUIT 1215 (WH/LG) • Key in OFF position. • Disconnect: PATS Transceiver C252. • Measure the resistance between PATS transceiver C252 Pin 4, Circuit 1215 (WH/LG), harness side and ground.
Yes GO to I9. No CHECK Circuit 1215 (WH/LG) for short to ground. If the circuit is OK, INSTALL a new instrument cluster; for additional information, REFER to Section 413-01. CYCLE the ignition to RUN using two encoded ignition keys. GO to Pinpoint Test J to initialize the module. REPEAT the self-test. CLEAR the DTCs. If the circuit is not OK, REPAIR Circuit 1215 (WH/LG). • Is the resistance greater than 100 ohms? REPEAT the self-test. CLEAR the DTCs. I9 CHECK THE PATS TRANSMIT CIRCUIT FOR CORRECT OPERATION — CIRCUIT 1215 (WH/LG) • Connect: PATS Transceiver C252. • Key in ON position. • Trigger the instrument cluster active command RF SIGNAL to ON. (Continued)
419-01-12 419-01-12 Anti-Theft — PATS
Test Step Result / Action to Take I9 CHECK THE PATS TRANSMIT CIRCUIT FOR CORRECT OPERATION — CIRCUIT 1215 (WH/LG) (Continued)
Yes GO to I10. No CHECK Circuit 1215 (WH/LG) for continuity to instrument cluster C220aPin 8. If the circuit is OK, INSTALL a new instrument cluster; for additional information, REFER to Section 413-01. CYCLE the ignition to RUN using two encoded ignition keys. GO to Pinpoint Test J to initialize the module. REPEAT the • Does the voltage drop from greater than 9 volts to less than self-test. CLEAR the DTCs. If the circuit is 1 volt when the instrument cluster active command is not OK, REPAIR Circuit 1215 (WH/LG). triggered on? REPEAT the self-test. CLEAR the DTCs. I10 CHECK THE PATS SYSTEM WITH A NEW PATS TRANSCEIVER INSTALLED • Key in OFF position. • Install a new PATS transceiver; for additional information, refer to Anti-Theft—Passive Anti-Theft System (PATS). Yes• Key in ON position. GO to I11.• Enter the following diagnostic mode on the diagnostic tool: Instrument Cluster On-Demand Self-Test. No • Is DTC B1681 retrieved? System is OK. I11 CHECK THE PATS SYSTEM WITH NEW INSTRUMENT CLUSTER • Key in OFF position. Yes • Install a new instrument cluster; for additional information, refer REPAIR Circuit 397 (BK/WH), 20 to Section 413-01. Cycle the ignition to RUN using two encoded (WH/LB), 1215 (WH/LG), and 1216 ignition keys. Go to Pinpoint Test J to initialize the module. (GY/OG). REPEAT the self-test. CLEAR REPEAT the self-test. CLEAR the DTCs. the DTCs. • Key in ON position. No • Enter the following diagnostic mode on the diagnostic tool: If no DTCs are retrieved, the system is Instrument Cluster On-Demand Self-Test. OK. • Is DTC B1681 retrieved? If other DTCs are retrieved, REFER to Instrument Cluster Diagnostic Trouble Code (DTC) Index.
PINPOINT TEST J: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PCM ID DOES NOT MATCH BETWEEN INSTRUMENT CLUSTER AND PCM
Test Step Result / Action to Take J1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. GO to J2. • Is DTC B2139 recorded? No System is OK. (Continued)
419-01-13 419-01-13 Anti-Theft — PATS
PINPOINT TEST J: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — PCM ID DOES NOT MATCH BETWEEN INSTRUMENT CLUSTER AND PCM (Continued)
Test Step Result / Action to Take J2 CLEAR PCM ID FROM INSTRUMENT CLUSTER AND PCM • Carry out the security access procedure for the instrument Yes cluster. For additional information, refer to Security VERIFY PCM calibration is correct for the Access—Procedure. vehicle. If correct, REPEAT Step J2. If • NOTE: DO NOT carry out ignition key code erase. fault code persists, INSTALL a new Select FSF card PARAMETER RESET command for instrument instrument cluster; for additional cluster. information, REFER to Section 413-01. • Use diagnostic card for PCM Active Command Keep Alive CYCLE the ignition to RUN using two Memory Reset. encoded ignition keys. REPEAT Pinpoint • Key in OFF position. Test J. CLEAR the DTCs. TEST the system for normal operation. If DTCSelect FSF card PARAMETER RESET command for PCM. B2139 still exists, INSTALL a new PCM;• Key in ON position. for additional information, REFER toTurn the ignition switch to RUN for three seconds. Section 303-14. REPEAT the self-test.• Enter the following diagnostic mode on the diagnostic tool: Clear CLEAR the DTCs.Continuous DTCs. • Key in OFF position. No • Enter the following diagnostic mode on the diagnostic tool: System is OK. CHECK for any other Retrieve Continuous DTCs. DTCs. REFER to the instrument cluster • Is DTC B2139 retrieved? Diagnostic Trouble Code Index.
PINPOINT TEST K: THE ANTI-THEFT SYSTEM DOES NOT OPERATE CORRECTLY — NVM CONFIGURATION FAILURE (NO PCM ID EXCHANGED BETWEEN INSTRUMENT CLUSTER AND PCM)
Test Step Result / Action to Take K1 USE THE DTCS FROM THE INSTRUMENT CLUSTER SELF TESTS • Use the recorded results from the Instrument Cluster Continuous Yes and On-Demand Self-Tests. If DTC B2141 only is retrieved, GO to K2. • Are any DTCs recorded? If DTC U1147 is retrieved with DTC B2141, GO to Pinpoint Test C. No System is OK. K2 CARRY OUT KEEP ALIVE MEMORY RESET FROM PCM • Use diagnostic card for PCM Active Command — Keep Alive Memory Reset. • Key in OFF position. • Key in ON position. YesLeave the key in the run position for thirty seconds. System is OK.• Key in OFF position. • Start the vehicle. No • Does the vehicle start? GO to K3. K3 RETRIEVE THE INSTRUMENT CLUSTER DTCS • Enter the following diagnostic mode on the diagnostic tool: Clear Yes Continuous DTCs. REPEAT K2. If the fault persists, verify the • Key in OFF position. PCM calibration. If the calibration is OK, • Key in ON position. INSTALL a new instrument cluster. for • Key in OFF position. additional information, REFER to Section • Enter the following diagnostic mode on the diagnostic tool: 413-01. Cycle the ignition key to run Instrument Cluster On-Demand Self-Test. using two encoded ignition keys. GO to • Is DTC B2141 retrieved? Pinpoint Test J to initialize the module. REPEAT the self-test. CLEAR the DTCs. No REFER to the DTC index
Old 04-18-2013, 07:25 PM   #2
What it boils down to is my theft light is flashing. I can not turn it off with a tuner. Any one have any easy tries that do not require a second key before I break the bank at the dealership.
Old 04-18-2013, 08:13 PM   #3
Project Pony's Avatar
Its cheap to get another key made. My local Ford dealership charged me about 100 bucks two cut and program two new keys, and reprogram pats onto my new pcm.
I think its 35-40 per key if I remember correctly.
[SIGPIC][/SIGPIC]
Old 04-18-2013, 09:59 PM   #4
That would be great! I hope it is a key, a C.P.S., or something simple. I tried to program a key on my own and found out it would not work. Maybe that is the problem. I already checked fuses 5,21,and 34.
Can any one take there key and shake it, to hear if the chip makes noise. Shake it like a salt shaker! I had the key cut at a local hard where store. They had a old key cutter and the key made a rattle noise after. The first key makes noise too. I do not know if the chip shook on the first key before.
More than one key shake reply would be appreciated.
Old 04-18-2013, 10:09 PM   #5
No, there should be no movement. If your chip is rattling around its likely your key is broke! It should be solid. Can you post a picture of your key? Youve got me curious.
[SIGPIC][/SIGPIC]
Old 04-18-2013, 10:24 PM   #6
You can only hear the noise if you take the key off the chain and put it near your ear.
Every time I try to upload pictures, they are too big of resolution. It is a ilco key. After the hurricane I lost 2 keys in 2 casinos, I worked at doing destruction. Getting paid to destroy stuff rocks.The Ile Of Caprie and the Imperial Palace. People came out and cut keys on site. The key is about 4 years old.
The car went down for a engine rebuild and the second key was ordered. I got lucky and it cranked once after I got the C.P.S. correctly adjusted. She purred with new rockers. But theft light ever since.
Old 04-18-2013, 10:45 PM   #7
Ghostedmind's Avatar
My key definitely makes no noise, on or off the key chain
LCMC Member
Old 04-18-2013, 10:55 PM   #8
Thanks, for shaking it like a salt shaker.
Do you think I should go for the top ten answers?
10:44 PM
