Primer color? - Mustang Evolution
Old 04-19-2013, 08:02 AM   #1
Blovett55's Avatar
Primer color?
Ok so I need to paint my rear quarter and door on passenger side back to stock color, they're new, my car got hit, the ford factory color is SU or tropical green if you don't want to look it up, my question is, should I use a white primer or grey primer to achieve my desired color
Blovett55 is offline   Reply With Quote
Old 04-19-2013, 08:04 AM   #2
Blovett55's Avatar
That picture is also of us banging dent out, so it could be driven temporarily until I got/painted new door and quarter
Old 04-19-2013, 09:22 AM   #3
samuelsmith's Avatar
Bad hit man. Hate it happened to you. I have always liked color urethane primer.
Old 04-19-2013, 09:27 AM   #4
Blovett55's Avatar
Well I actually bought it that way, the guy sold it for $900 because of that, it's worth so much more, so can't pass up deals like that
Old 04-19-2013, 06:23 PM   #5
Use the grey primer, I work in a body shop and the painters prefer using that instead of white.
Redstang19 is offline   Reply With Quote
Old 04-19-2013, 08:38 PM   #6
Blovett55's Avatar
How much darker will this make the color of the base that I will be spraying on it
---------- Post added at 08:38 PM ---------- Previous post was at 08:37 PM ----------
And is there any certain shade of gray or type of primer gray I should be using
Old 04-19-2013, 08:42 PM   #7
Ubnbit's Avatar
Are you gonna paint it or take it and have it done? If you have it done, they will take care of it. If you are gonna do it yourself, there is a pretty good lot to it. If you go to where you plan to buy the paint, they will give you what you need to make it turn out best. Get the spec sheets on the paint system you want to use and read them. The guys you buy it from will help you a lot. Gray primer is the way to go. There are primers, sealers, and primer/sealers.
Old 04-20-2013, 05:54 AM   #8
Blovett55's Avatar
Yeah, I'm doing it myself, I sprayed cars before, but it was only black, and black is pretty easy with the primer and base coat
Old 04-20-2013, 08:54 AM   #9
Their are different types of primer, the grey is meant for painting and I think their is only one type of grey primer. The white primer isn't really meant for paint its used more if a rock guard or something like that is being sprayed on top of it. If you've done spraying before then use the same technique you used before, only difference is you are using a different color.
Old 04-20-2013, 01:26 PM   #10
Blovett55's Avatar
Thanks, yeah I wasn't really sure, since it's a brighter Green, I wasn't sure if I needed to use a white or a grey primer, like I said I only have sprayed cars with black, and you just use a black primer and black base under the clearcoat, very easy to do
Old 04-20-2013, 01:31 PM   #11
Ubnbit's Avatar
You can spray black over gray primer as well. If you use an enamel paint, you won't even have to use a clear. Just don't use enamels with metallics.
Old 04-20-2013, 08:29 PM   #12
Blovett55's Avatar
Alright thanks alot
12:02 PM
