Exhaust - Mustang Evolution
Old 04-20-2013, 06:23 PM   #1
TM2189's Avatar
Exhaust
This is my exhaust pipe, any suggestions on a fix so it can pass inspection until I can get it welded.
TM2189 is offline   Reply With Quote
Old 04-20-2013, 06:29 PM   #2
Torchredfrankie's Avatar
We're do you live? If in CA as long as you have a 3 inches of pipe after the cats your good
Torchredfrankie is offline   Reply With Quote
Old 04-20-2013, 06:30 PM   #3
sam62893's Avatar
Ummm, only option is getting it welded at the exhaust shop unless you know how to weld.
Old 04-20-2013, 06:33 PM   #4
TM2189's Avatar
I live in Texas. I'm mainly worried about breaking a sound law.
Old 04-20-2013, 06:33 PM   #5
Or take the back piping off like I stated above as long as you have 3 inches of piping from the cats back your good
Old 04-20-2013, 09:06 PM   #6
TM2189's Avatar
Fixed it.
Old 04-20-2013, 09:41 PM   #7
sam62893's Avatar
Duct tape and clamps?
Old 04-20-2013, 09:43 PM   #8
TM2189's Avatar
Sheet metal, hose clamps and bailing wire.
Old 04-20-2013, 11:54 PM   #9
sam62893's Avatar
I don't think that'll hold very well as its not airtight. It could be the cause if your shaking as well. Try making it airtight around the seams. Metal on metal doesn't make a very good seal if not welded
Old 04-21-2013, 12:38 AM   #10
There are "permanent" clamps that'll work.
LINK:BORLA® 18004 - Stainless Steel Band Clamps (2.50" Dia.)
Old 04-21-2013, 01:22 AM   #11
goodwinta1's Avatar
Those are a pretty sexy alternative (bandaid) to welding. Honestly didn't know they existed.
goodwinta1 is offline   Reply With Quote
Old 04-21-2013, 03:07 AM   #12
tc x 4's Avatar
Unless you use rusty wire, it'll never work.
Old 04-21-2013, 06:37 AM   #13
Rm360's Avatar
All you need is an exhaust pipe coupler, you will need to cut a small section of the exhaust out slide coupler in, clamp with exhaust clamps and bam!! Permanent fix!!
Old 04-21-2013, 08:53 AM   #14
TM2189's Avatar
I plan on getting new exhaust anyway. This is to hold me over so I can pass inspection.
Old 04-21-2013, 09:12 AM   #15
1slosix's Avatar
Advance sells those clamps to fix broken pipes
carving corners like a boss
10:21 AM
