Exhaust bolts - Mustang Evolution
Old 04-20-2013, 06:41 PM   #1
sam62893's Avatar
Exhaust bolts
Okay so I got my '97 shell on stands and I'm truing to see how I'm going to bolt on the exhaust. The exhaust is completely out of the car with the y pipe disconnected and the muffler and tail zip tied to the car. I wanted to take the bolts off to connect the muffler end to the y pipe but it seems like its too rusted. Should I cut them off and get a new set? Or is there a better way? I can't get any leverage to properly attempt to unscrew them. And if I cut them off, does anyone know where I can get a new set of bolts? And no I can't take it to an exhaust shop it's a shell on stands
ID:	103494   Click image for larger version
Old 04-20-2013, 07:22 PM   #2
Ghostedmind's Avatar
autozone sells the bolts. i have some new ones in the SN95 stock exhaust manifolds i plan to put in my car once my stock ones give out again
LCMC Member
Old 04-20-2013, 07:30 PM   #3
samuelsmith's Avatar
Wd40 and give it a try. Some times the bolts will go back in. I'd go with stainless steel because of the restless factor. Do you have a local nut and bolt store?
Old 04-20-2013, 07:57 PM   #4
sam62893's Avatar
I pretty much soaked them in WD40 and let them sit for 2 nights. I cut them off already so I guess I'll have to buy new ones anyways. Ill check autozone, if not I have a local ACE hardware store that I'm pretty sure sells them. So stainless steel nuts and bolts is the way to go then?
Old 04-24-2013, 07:15 AM   #5
Get a propane tank and heat them up learned the hard way will save u lot of time and money
Bakiebruno5 is offline   Reply With Quote
05:36 AM
