Shaking - Mustang Evolution
Old 04-20-2013, 09:58 PM   #1
TM2189's Avatar
Shaking
Recently got my car running but it shakes more than I would deem normal. Any suggestions as to possible cause? I've been told bad motor mounts but I'm not sure.
TM2189 is offline   Reply With Quote
Old 04-20-2013, 10:15 PM   #2
Ubnbit's Avatar
Are you talking more than a tire out of balance?
Old 04-20-2013, 10:19 PM   #3
TM2189's Avatar
Yes, the cars not even moving and it shakes a lot.
Old 04-20-2013, 10:31 PM   #4
Ghostedmind's Avatar
engine mounts good?
or maybe a one sided misfire
LCMC Member
Old 04-20-2013, 10:32 PM   #5
TM2189's Avatar
Originally Posted by Ghostedmind View Post
engine mounts good?
I haven't been able to check them yet. I was hoping it might be something a little easier to deal with.
Old 04-20-2013, 10:41 PM   #6
Well, the engine mounts shouldn't be to hard to check. You should be able to see them fairly easily, just grab a good source of light and check them out.
LCMC Member
Old 04-20-2013, 10:42 PM   #7
TM2189's Avatar
Sounds good, ill do that in the morning. What should I check for as far as signs of wear.
Old 04-20-2013, 10:47 PM   #8
cracks, loose/missing bolts
LCMC Member
Old 04-21-2013, 07:24 AM   #9
samuelsmith's Avatar
My front end shakes a little like a cam is loping and causing the body to shake. I don't know what to tell you to fix the shake.
Old 04-29-2013, 10:43 PM   #10
andregayola's Avatar
try to take ur tires off and put another set i had the same problem and it ended up being my wheels weren't aligned properly causing them to shake
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 04-30-2013, 12:39 AM   #11
He said it shakes when he isn't moving
---------- Post added at 01:39 AM ---------- Previous post was at 01:36 AM ----------
Should have mentioned this earlier. To check a misfire, you can hear it most of the time, but if you pull a plug wire off one at a time, and each on causes the engine to run rougher then its not a specific misfire
I do, know that our cars have a wired problem with running rough which I've beef working on since I bought my car. And about 10 other people on the forums have the same problem, both GTs and V6s. Mine cleaned up a bit when I cleaned the EGR ports inside my lower intake.
You can also try doing the following as well:
-Tune-up
- Spark Plugs
- Plug Wires
- Replace Coil Pack
- Clean the Mass Air Flow (MAF) Sensor
- Clean the Idle Air Control (IAC) Sensor
If you try to clean your MAF take caution and do not damage it. There is a special cleaner that is recommended you use to clean it. You should be able to find it at Wal-Mart, Autozone, e.t.c. It's just called Mass Air Flow sensor cleaner, red and white can with a black lid. Before you replace your coil pack test it. If you have a Haynes manual it will tell you how. If you don't have one I can take a picture of the steps and post them up for you (you have to have a multimeter)
LCMC Member
Old 05-01-2013, 12:32 AM   #12
At the moment, my car will shake and rumble when the cooling fan comes on. It's intermittent, so it may not be the same problem that you're having, but it's worth a check.
NickieNay is offline   Reply With Quote
05:37 PM
