Check engine light - Mustang Evolution
Old 04-21-2013, 09:15 AM   #1
Blovett55's Avatar
Check engine light
Okay so I've been having this problem for quite some time lately, My check engine light, or for mustangs the service engine soon light came on, put a scanner on it, the code came back with a camshaft sensor, replaced it, cleared the code and after about 3 days on average, same code and light come back on, so I was wondering if anyone else gets this B/S code, or if they know what the real problem is that is throwing out a bad/wrong code
Blovett55 is offline   Reply With Quote
Old 04-21-2013, 11:26 AM   #2
Ghostedmind's Avatar
Sometimes electronics will just go bad, (even if it's brand new) this time I suggest testing the Camshaft Position Sensor (CPS) according to a Haynes manual before you just replace it. because it could just need cleaning. If you clean it up and it tests good then I would look deeper than just the CPS. I would look to see if there is something causing it to go bad. Never trust the SES/CEL codes 100%, always inspect the part.
LCMC Member
Old 04-21-2013, 12:04 PM   #3
Blovett55's Avatar
No, when I took it off, it looked fine, but the part was only 20 so I went ahead and threw the new part on
Old 04-21-2013, 10:56 PM   #4
SpeedyG's Avatar
I got the same code recently, mechanic told me to reset it and just keep driving it will go away. He checked it and mine was fine, could be a bogus code especially if you changed it new.
SpeedyG is offline   Reply With Quote
Old 04-22-2013, 05:52 AM   #5
Blovett55's Avatar
So even though I put a new one in and still getting the code, just every time it comes up just clear the code, because it'll come back on in about 4 days, I mean it doesn't run wrong at all but the light just bothers me because u can't always tell something is wrong by the sound
Old 04-22-2013, 11:16 AM   #6
Berry_Eggo's Avatar
Try removing your battery for 5min then place it back
Berry_Eggo is offline   Reply With Quote
02:21 PM
