My car likes to eat spark plugs - Mustang Evolution
Old 04-21-2013, 04:46 PM   #1
sam62893's Avatar
Just that. My car eats them for lunch. A couple of months ago I replace my spark plugs. Everything was fine and then the car threw the SEL at me and showed that cylinder #1 was misfiring. Didn't think much of it so I kept driving with my car bogging down and popping every once in a while. So 2 weeks ago it started bugging me. I went and replaced the #1 plug and checked a couple of them as well. Of course they were pretty fine but #1 was melted. An also some of the plugs had oil in them. what could have caused that? So anyways, I cleared the code and last week it started misfiring again and the SEL lit up again with the same code. So I'm going to replace the wires and plugs today.
What could cause my car to eat up my plugs? And should I be worried about oil on my plugs?
One last thing, what plugs should I use? Can I use the MSD ones from autozone or are they crap?
Old 04-21-2013, 05:44 PM   #2
fastmustangs1's Avatar
wat plugs you running now. Try the Motorcrafts!
fastmustangs1 is offline   Reply With Quote
Old 04-21-2013, 05:44 PM   #3
Ghostedmind's Avatar
First off, i've always heard that Motorcraft coppers are the best for our engines, with the autolite copers being a close second. In your case, for now, I would ONLY replace with those because they are also some of the cheapest ones. (saves you a little cost on plugs if you are chewing them up)
Second, the oil on the plugs could be from a couple things from a blown head gasket to worn piston rings. AND if i'm correct, oil on your plug when it fires could cause it to burn up like that.
LCMC Member
Old 04-21-2013, 06:26 PM   #4
Tyoung68's Avatar
Or your valve seats are bad
Old 04-21-2013, 08:42 PM   #5
sam62893's Avatar
I'm currently running the motorcraft coppers. I'm going to replace them with motorcraft coppers again and a new wire set as well
---------- Post added at 09:41 PM ---------- Previous post was at 09:41 PM ----------
The car runs fine, just misfires every once in a while. Doesn't overheat or anything
---------- Post added at 09:42 PM ---------- Previous post was at 09:41 PM ----------
Valve seats, ill check it out
Old 04-21-2013, 08:45 PM   #6
It's not me, it's you.
primer2tone's Avatar
I'd put my money there. That's the most common seal to fail before rings and head gaskets.
Old 04-22-2013, 12:00 AM   #7
sam62893's Avatar
Would they be easy to replace or would I have to take it to a shop? I have SOME mechanical expertise but in no way am I a master tech, I'm still studying.
Old 04-22-2013, 12:04 AM   #8
Tyoung68's Avatar
You would have to take it some where they machine the old seats out and press new ones in and machine them for your valves
Old 04-22-2013, 01:54 AM   #9
tc x 4's Avatar
My moneys on valve seals, seats usually cause a lose of compression.
Old 04-22-2013, 02:04 AM   #10
tc x 4's Avatar
Several things could cause the plugs to melt.
Here are just a few, timing advanced to much, a/f mix to lean, intake manifold leaking.
Old 04-22-2013, 02:23 AM   #11
Before you start changing things, I'd suggest a compression test. That'll rule out a lot of possibilities.
Old 04-22-2013, 02:28 AM   #12
tc x 4's Avatar
+1, that's a good place to start along with checking timing.
Old 04-22-2013, 02:32 AM   #13
Yeah, timing would have been my next suggestion. Even a little slack on the chain can cause serious problems.
Old 04-22-2013, 02:36 AM   #14
tc x 4's Avatar
A step colder plug will help if oil is getting on the plugs causing them to over heat.
Old 04-22-2013, 06:51 AM   #15
sam62893's Avatar
I already got my plugs and wire set so I'm changing that regardless. Ill run a compression test to be sure as well. I'm not going to dump anymore money in this car though. I'm just going to sell it. Tranny going bad and this while spark plug deal is killing me. I'm trading my other car soon for an 02 V6
07:43 PM
