Acceleration Mods - Mustang Evolution
Old 04-23-2013, 09:26 AM   #1
SpeedyG's Avatar
Acceleration Mods
Looking to get some more pony's off the line. What acceleration mods do you guys suggest? 2000 v6 vert. For now just have CAI and short throw shifter. budget friendly if possible . Thanks!
SpeedyG is offline   Reply With Quote
Old 04-23-2013, 09:28 AM   #2
Project Pony's Avatar
How much are you looking to spend?
[SIGPIC][/SIGPIC]
Old 04-23-2013, 10:14 AM   #3
Dantheman94's Avatar
Do 3.73 or 4.10 gears, limited slip diff, a tuner, and control arms help too
Dantheman94 is offline   Reply With Quote
Old 04-23-2013, 10:54 AM   #4
SpeedyG's Avatar
Around $500
Old 04-23-2013, 11:38 AM   #5
fastmustangs1's Avatar
Like others mentioned gears prolly your best bet man.
fastmustangs1 is offline   Reply With Quote
Old 04-23-2013, 11:38 AM   #6
Sluder4's Avatar
Best bang for your buck that's about 500 is a set of 3.73 gears or 4.10s. Installation and parts is around 500
1999 V6 Mustang Dark Satin Green , SR CAI, BBK 65mm Throttle Body, Screaming Demon Coil Pack, SR Lowering Springs, Pioneer Stereo, 2 12' inch subs and 1600watt amp, Green Calipers,
Sluder4 is offline   Reply With Quote
Old 04-23-2013, 11:52 AM   #7
1slosix's Avatar
gears, tune, and gas pedal adjustment lol
carving corners like a boss
Old 04-23-2013, 04:57 PM   #8
Siendly22's Avatar
I have 8.8 rear differential with 3.73 and race tune from bama and you can feel the magic of your car hehe
Siendly22 is offline   Reply With Quote
Old 04-23-2013, 05:02 PM   #9
SpeedyG's Avatar
What's the difference between the 2? And can they be installed alone or do I need a time or other parts to go with it?
Old 04-23-2013, 05:12 PM   #10
Siendly22's Avatar
I can say get a tuner from AM and gears. You can feel a big difference. I have 8.8 rear end with 3.73 and tuner it wakes up my car..
Old 04-24-2013, 12:20 AM   #11
davidcseifert's Avatar
Region: Arkansas
For gears LSD install kit fluid and labor you're looking at close to $900 or more if you buy all new.. You can get away cheaper by doing the 8.8 swap and just putting gears in it.
As for tuners, my recommendation is Ortiz Performance, his tunes aren't as conservative as AM's lol
blower/new cam soon
Old 04-24-2013, 08:08 AM   #12
Sluder4's Avatar
3.73 is for automatics that want to eventually add turbo or supercharge their rides. 4.10s are for manuals from what I've seen posted on here. Plus if its a DD then you'll run higher RPMs with them both but defiantly more with the 4.10s.
And yes you'll need the part that sets your speedometer correctly since it gets way of with new gears. I'm not an expert so if any of this info isn't right someone correct me :p
So if automatic go with 3.73s and manual go with 4.10s
Old 04-24-2013, 09:06 AM   #13
SpeedyG's Avatar
I have a manual so I should get the 4.10s ?? What else would I need??
Old 04-24-2013, 09:15 AM   #14
No noo no no. Thats backwards. Auto = 4.10 - 5-speed = 3.73
[SIGPIC][/SIGPIC]
Old 04-24-2013, 12:32 PM   #15
Torchredfrankie's Avatar
+1
Torchredfrankie is offline   Reply With Quote
Old 04-24-2013, 04:07 PM   #16
samuelsmith's Avatar
If you do not do gears the Windstar upper is a good choice.
Old 04-24-2013, 05:14 PM   #17
SpeedyG's Avatar
I think I'm going with the gears, simple to install on my own?
Old 04-24-2013, 07:24 PM   #18
No, setting the backlash is not something you should try and do yourself without any experience. You can cause some real damage and chew up your new gears.
[SIGPIC][/SIGPIC]
05:45 PM
