Changing head gaskets - Mustang Evolution
Old 04-25-2013, 11:40 AM   #1
I have an oil leak around the heads on my wife's 04 mustang v6. I was quoted $300 to change them. Is this something that is relatively easy to do? It seems like all you need to do is take the intake manifold off and from there it looks painless. So what do you think? Should I attempt it myself?
---------- Post added at 11:40 AM ---------- Previous post was at 11:40 AM ----------
Changing the gaskets...not the heads. Sorry of that was unclear.
Mikeyt03 is offline   Reply With Quote
Old 04-25-2013, 11:46 AM   #2
Project Pony's Avatar
If your even slightly mechanically inclined you will have no issue. Its actually pretty straight forward.
[SIGPIC][/SIGPIC]
Old 04-25-2013, 11:59 AM   #3
sam62893's Avatar
Yeah pretty easy and hard at the same time. I THINK you have to take off valve covers (replace those gaskets as well) take off the intake manifold and then the heads might as well clean out everything while the engine is open. Then take off old gasket and put the new one in
Old 04-25-2013, 12:03 PM   #4
Ok good. That's what I thought. I'm going to order the gaskets and try it myself. While I've got things apart, is there anything else I should be replacing as well?
---------- Post added at 12:03 PM ---------- Previous post was at 11:59 AM ----------
I actually think he said valve cover gaskets. Either way I'm going to change them all.
Old 04-25-2013, 12:52 PM   #5
davidcseifert's Avatar
Region: Arkansas
First off, oil leak? You mean coolant leaking into the oil maybe? There are no pressurized oil passages in the heads just the drain backs but no pressure on them nor are they even through the main head gasket area..
Just curious before you go ripping it all down, what are all the symptoms the car has right now
As for the head gasket swap yes it's relatively easy, you can pick up a Haynes/chiltons manual for the torque specs and all too, granted there are no hold ups should easily do it in a day
blower/new cam soon
Old 04-25-2013, 12:58 PM   #6
The tech said that oil is leaking from the valve covers. I'll take a pic when I pick it up. I definitely see the oil he is talking about but I've never noticed it before. He said changing the gaskets would fix it. I wasn't really paying attention to him very much, because I figured if there was an issue, I could fix it myself for much cheaper so I told him I didn't want him to touch it. Thoughts?
Old 04-25-2013, 01:00 PM   #7
Region: Arkansas
Lmao you just need to change valve cover gaskets... Not a $300 job
blower/new cam soon
Old 04-25-2013, 01:02 PM   #8
Ok good. I figured I need to take the intake manifold off, and the valve cover and I'm good to go. I'll change the gasket in the manifold the same time.
Old 04-25-2013, 01:04 PM   #9
Region: Arkansas
Yeah pretty sure the upper intake gasket isn't reusable
blower/new cam soon
Old 04-25-2013, 02:02 PM   #10
sam62893's Avatar
Yeah, if its the valve cover gaskets, no need to replace the head gaskets lol. The upper intake gasket is about 40-50 bucks at autozone I'm not sure about the valve cover gaskets though. Make sure to clean off the gasket residue real good before putting on the new ones. And it would also be a good time to paint your valve covers if you feel artsy.
And the intake gasket isn't reusable. I stripped my iac bolts on my manifold and I switched manifolds and reused my gasket. I don't feel a difference though. What problems would reusing that gasket cause?
06:13 PM
