2003 mustang grinding sound - Mustang Evolution
Old 04-27-2013, 09:24 PM   #1
FriedChicken's Avatar
Yesterday I was at a friends house parked on his driveway which is a steep hill. I went I put the car in drive I heard a loud popping sound and now anytime I brake or cruise at low speeds I get a metal grinding sound in the front left of my car?! Any suggestions? Thx
FriedChicken is offline   Reply With Quote
Old 04-28-2013, 12:22 AM   #2
Tyoung68's Avatar
Ebrake ?
Old 04-28-2013, 01:36 AM   #3
Region: Iowa
Material between pads and rotor , or your caliper is locked on and won't relieve itself from the rotor
Iowaboy13 is offline   Reply With Quote
Old 04-28-2013, 09:32 AM   #4
Its not the ebrake. If I jack it up would I be able to see the material between the pad and rotor.
Old 04-28-2013, 01:18 PM   #5
Skargon's Avatar
Yes, their is an inspection spot on the caliper, and you can actually see it from either side of the caliper, If they are very low, or the Rotor itself has grooves or lines drug into it, I would consider a front brake job immediately. possibly a rear as well.
It's really easy to pop the Caliper up, if I am not mistaken it is a Torx 45 bit, and you will be looking directly at sliding the caliper upwards to check the pads.
Inspect them for cracks or damaged edges, and replace immediately if you notice anything suspicious, it's cheap and quick to do and can save you money in the long run.
Don't forget if you dissassemble it is a good time to re-lube your slide pins with some silicone lubricant, and the surface of the brake caliper bracket that touches the pads with some silver anti-sieze.
It takes a decent mechanic around 10 minutes per side to do brakes, so about a 40-50 minute job if you do it at a decent pace, and an hour maybe if you are going to bleed the brake system as well, which is highly recommended.
Hope this helps bro, Good hunting.
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 04-28-2013, 01:32 PM   #6
Thanks guys for all the help. I checked all my brakes and they all look good except for the drivers side rotor which has grooves in it. Which is where the grinding is coming from. I am replacing the brakes tomorrow and turning the rotors. Thx again guys!
Old 04-28-2013, 06:04 PM   #7
Skargon's Avatar
No problem man, Glad we could shed some light, Just have fun and if you ever need us again, we'll be here.
Plus we encourage you to stick around, Hang out, just chat it up from time to time.
The site is free, but trading information makes us all rich.
1998 Mustang V6
16.5 1/4 Mile
05:06 PM
