Radiator and power steering flush - Mustang Evolution
Old 04-29-2013, 05:26 PM   #1
Xaperez100's Avatar
I've never flushed anything and was wondering how to flush both?
Xaperez100 is offline   Reply With Quote
Old 04-29-2013, 05:32 PM   #2
Ghostedmind's Avatar
The radiator flush is fairly simple. You buy a bottle of the flush chemical and the directions are on the back of it. But basically you drain your radiator (and reservoir) pour in the flush chemical and top off with water. Let it run for like 10-15 min with the heater on the highest setting. then drain and run straight water through then fill with 50/50 and devil the reservoir
Never done the power steering though I was wondering about that as well
LCMC Member
Old 04-29-2013, 05:54 PM   #3
Xaperez100's Avatar
Hmm okay seems simple.. Also how do I drain the radiator and reservoir ?
Old 04-29-2013, 06:38 PM   #4
The reservoir I've never looked at so I'm not sure, but the radiator should have a drain plug on the bottom door you can pull the bottom hose....just be careful with that.
LCMC Member
Old 04-29-2013, 06:41 PM   #5
Xaperez100's Avatar
Oh okay alright thanks!
04:58 PM
