Gas tank removal - Mustang Evolution
Old 04-29-2013, 09:50 PM   #1
Xaperez100's Avatar
Gas tank removal
Well I've tried taking it out before but it won't seem to budge.. I think it's cause of the lines connected to it.. But does anyone know how many fuel lines I need to remove from it?
Xaperez100 is offline   Reply With Quote
Old 04-29-2013, 09:59 PM   #2
1slosix's Avatar
here's what i found on google really quick
1ST start by draining the gas tank as much as possible, its a lot better if someone can help you, that son of a tank is going to give you a hard time if you do it by your self, and with a full tank.. oh and by the way I don't know if you have and idea how to remove the back bumper, but if you do I suggest you do it, that saved me from getting me mad and breaking a window on my ride. start by removing the 3 bolts on the gas filler neck, you know when you open the fuel door you'll see the 3 bolts around, can't miss em. go inside your trunk and remove the hose thats connected aside of the neck. Now heres the hard part. Remove the fuel filter line, and then bolts attached to the gas tank straps... Once you done that, try to drop the gas tank all the way, try using a jack so that you can drop the tank slowly, if you can try to remove all the hoses you see that are keeping the gas tank from being dropped, I mean common sense right?? the gas filler neck kind of gets on the way pretty bad, so once all the hoses are out, pull the gas filler neck out, I mean out!!! don't worry its kind of long but just pull it out, "of course the filler neck" its going to come out with the seal, but no worries it ill be fine. Just use common sense and take out all the bolts and parts that are on your way. Just make sure you remember how to put them back.
carving corners like a boss
Old 04-29-2013, 10:27 PM   #3
Xaperez100's Avatar
Hmm okay
Looks like I need a fuel line disconnect tool..
But how would I get the gas out? I've tried syphoning but it doesn't seem to work.-....
Old 04-29-2013, 10:29 PM   #4
1slosix's Avatar
yeah i believe our cars have a anti siphon line in the filler tube. when my friend dropped his he didn't drain the gas...he just was really careful dropping it with the jack
Old 04-29-2013, 10:37 PM   #5
Xaperez100's Avatar
Mines fine. It has like a quarter of gas but the gt has like half.-.
Old 04-29-2013, 10:38 PM   #6
1slosix's Avatar
is your tank damaged? is that what the swap is for?
Old 04-29-2013, 10:41 PM   #7
Xaperez100's Avatar
Well my seal for the filler neck is and the fuel pump is bad. So I might as well just switch the entire thing out..
Old 04-29-2013, 10:44 PM   #8
1slosix's Avatar
i guess lol
Old 04-29-2013, 10:48 PM   #9
Xaperez100's Avatar
i guess lol
Plus it has more gas in it so ill have more gas to:p lol
Old 04-29-2013, 10:52 PM   #10
1slosix's Avatar
i don't think i'd use the gas in it lol
Old 04-29-2013, 10:55 PM   #11
Xaperez100's Avatar
Haha whys that? It's only been sitting for about two weeks..
Also does the filler neck divide into two pieces?
Old 04-29-2013, 10:56 PM   #12
1slosix's Avatar
because gas breaks down after a few weeks of sitting...run at your own risk as for the filler neck i'm not sure
Old 04-29-2013, 11:45 PM   #13
Xaperez100's Avatar
Oh well it hasn't been sitting that long..
Old 04-30-2013, 12:45 AM   #14
1slosix's Avatar
3 weeks is the average time needed for gas to break down
Old 04-30-2013, 11:19 AM   #15
davidcseifert's Avatar
Region: Arkansas
3 weeks since when? My car was left setting for a month and half before I put gas in it again and it ran fine while still using the old gas, it's 90 days for E10
blower/new cam soon
Old 04-30-2013, 01:42 PM   #16
Xaperez100's Avatar
Switched out the fuel pumps and put a new seal.. Had to do some wiring but that's it. Took a while cause I did it alone and on the ground. But overall it was easy.
Old 04-30-2013, 01:44 PM   #17
take good pics, do a write up, and get it up on the forum as a how to
Old 04-30-2013, 02:05 PM   #18
Xaperez100's Avatar
Dang. Okay I'm gonna have to do it again:p lol I should have thought about that... I have an 03 gt to do work on so ill do write ups when I get to that one
Old 04-30-2013, 07:32 PM   #19
sam62893's Avatar
The 02 I just got was sitting around for 2 months or more until I got it. Had a quarter of a tank left in it and it ran just fine
Old 04-30-2013, 08:10 PM   #20
1slosix's Avatar
you could do a write up for AM as well. they don't have one on there and if yours is good enough to use they'll pay you up to $200 for that
Old 04-30-2013, 09:21 PM   #21
Xaperez100's Avatar
Really? Hmm sounds good to me! The only problem I had was getting off the lines that go into the other plug away from the fuel pump
« Strut bar | Shaking »
05:57 PM
