problem - Mustang Evolution
Old 04-30-2013, 06:37 PM   #1
V6in's Avatar
problem
So my grandpa has a 02 V6 with 160xxx miles. Its really gettin sluggish taking off and while its sitting at idle its like the engine is rumbling or rocking back and forth. Last thing is that when I got done taking it for a ride it smelled really funny. All gauges read fine. It said service engine soon. So I figure maybe just a tune up and such. If so what do I need and what should I do. Thanks
V6in is offline   Reply With Quote
Old 04-30-2013, 06:39 PM   #2
maldog's Avatar
Region: Nevada
Try to get the codes read and see what's going on?
2006 Mustang GT Premium RedFire. CAI, SLP Loudmouth, SCT Progammer, 5 speed manual trans. My other car is a CORVETTE!
maldog is offline   Reply With Quote
Old 04-30-2013, 06:39 PM   #3
TaylorF25's Avatar
Sounds like a bad coil pack, almost exactly how mine acted when mine went bad
TaylorF25 is offline   Reply With Quote
Old 04-30-2013, 07:23 PM   #4
Xaperez100's Avatar
Check for any break in the wires also.. Happened to me one wire was hitting the engine and sparking.. Made it drive like that
Xaperez100 is offline   Reply With Quote
Old 04-30-2013, 07:28 PM   #5
V6in's Avatar
Thx guys ill do some more searchin too
Old 05-01-2013, 12:36 AM   #6
What did it smell like? Was there any fluid on the ground, or anywhere in the engine bay?
NickieNay is offline   Reply With Quote
Old 05-01-2013, 03:10 AM   #7
Skargon's Avatar
Just do a tune up, it's really easy on these 3.8's..
Plugs, wires, coil pack = less than 100$ bought all together..
Air filter, clean MAF, IAC, IAT, Etc.
Basically clean up everything and tune up things, even if the problem is solved, Its an old car with 100k+ Miles, tune up everything.
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 05-01-2013, 04:15 PM   #8
V6in's Avatar
Ok but what's maf and iat and how do I clean them.
---------- Post added at 05:15 PM ---------- Previous post was at 05:14 PM ----------
It wasn't oil or gas but it was almost like a musty smell. I can't recall smelling anything like it... It doesn't leak anything either.
Old 05-01-2013, 04:27 PM   #9
Xaperez100's Avatar
Mass airflow sensor and idle air control
Old 05-03-2013, 10:34 PM   #10
It wasn't oil or gas but it was almost like a musty smell. . .
Was your grandpa still in it? :p
Jkjk
Old 05-04-2013, 01:23 PM   #11
V6in's Avatar
Jkjk
Lollll
Old 05-11-2013, 08:28 PM   #12
V6in's Avatar
So I fixed it, I'm pretty sure it was the coil pack. But I also put in new spark plugs and wires. And I went to auto zone to see why it said service engine soon light was still on and she said the #1 and #3 cylinders are misfiring. So I was wondering if that was from before or after what I did that made the cylinders misfire?
Old 05-12-2013, 08:47 AM   #13
V6in's Avatar
Anyone?
Old 05-12-2013, 08:59 AM   #14
twotone01's Avatar
Clear the codes and see if they come back and that'll let you know if you've fixed it or not haha
twotone01 is offline   Reply With Quote
Old 05-12-2013, 09:19 AM   #15
V6in's Avatar
Ok ill try that ha
Old 05-12-2013, 04:51 PM   #16
V6in's Avatar
Could the problem be from anything I did? Maybe cross the wires or something
10:23 PM
