Rear sway bar - Mustang Evolution
Old 04-30-2013, 07:21 PM   #1
Xaperez100's Avatar
Will a rear sway bar from a 2003 gt fit on my car?
Xaperez100 is offline   Reply With Quote
Old 04-30-2013, 07:24 PM   #2
slow281
sixpac's Avatar
Region: Nebraska
Originally Posted by Xaperez100 View Post
Will a rear swag bar from a 2003 gt fit on my car?
Yes
Need more Horsepower? Add a sticker. Contact me for vinyl stickers pre-made and custom!
Stick on Horsepower <- Click Here and like my Page!
2001 GT - True Blue
2003 V6 - Zinc Yellow
1990 LX 2.3 - project
sixpac is offline   Reply With Quote
Old 04-30-2013, 07:25 PM   #3
Xaperez100's Avatar
Originally Posted by sixpac View Post
Yes
Do I have to do any modification? Or just bolt it on?
Old 04-30-2013, 07:35 PM   #4
lemons95's Avatar
What's a swag bar? sounds weird... I don't think you want it.
Now something that's similar is a sway bar. It should fit. I'm not 100% sure since the axles are different. BUT i think I read that they do fit.
Old 04-30-2013, 07:37 PM   #5
sam62893's Avatar
Swaaaaagggggg.....
But yeah it should fit snug, no modifications. The body is exactly the same
Old 04-30-2013, 07:37 PM   #6
Xaperez100's Avatar
Originally Posted by lemons95 View Post
What's a swag bar? sounds weird... I don't thing you want it.
Lmao sorry stupid spell check -.- but alright well ill have to see!
Old 04-30-2013, 07:39 PM   #7
sam62893's Avatar
Boom
ID:	105317   Click image for larger version
Old 04-30-2013, 07:43 PM   #8
Xaperez100's Avatar
Originally Posted by sam62893 View Post
Boom
Sweet thanks! I have this 03 gt that doesn't run with all these parts:p
Old 04-30-2013, 07:47 PM   #9
sam62893's Avatar
Dude, if you have the whole GT send me some parts!!
Old 04-30-2013, 07:58 PM   #10
fastmustangs1's Avatar
A smaller diameter rear sway bar will increase rear grip downside it will increase understeer. Other hand larger diameter will oversteer and will make it feel like car wants to spin out in a corner. It will feel like it increases steering in the car.
fastmustangs1 is offline   Reply With Quote
Old 04-30-2013, 08:02 PM   #11
Xaperez100's Avatar
So ill get oversteer?
---------- Post added at 09:02 PM ---------- Previous post was at 09:02 PM ----------
Like?:p
Old 04-30-2013, 08:05 PM   #12
sam62893's Avatar
Fogs? Rear seats. Stereo door handle where the lock and unlock buttons at. Hood scoop. Rear bumper, side scoops. Rear wheel bearings. Third taillight hahaha I need plenty xD
Old 04-30-2013, 08:08 PM   #13
1slosix's Avatar
to be honest you won't get the fishtail feeling when you put that GT bar on. especially since you don't have one stock. One of my favorite things i've done so far was pop a GT bar on. of course they used a handful of sizes throughout the years. along with using both hollow and solid bars. in the end no matter what you'll enjoy putting it on. you'll need to use two of the bolts from the GT. your v6 will have 2 of the other bolts already under there because they hold some lines in place
carving corners like a boss
Old 04-30-2013, 08:12 PM   #14
Like?:p
depends wat size the bar is.
Old 04-30-2013, 09:22 PM   #15
Surffer227's Avatar
I pulled one from a 98 in a junk yard, bolted directly in, 10 minutes max
Surffer227 is offline   Reply With Quote
Old 04-30-2013, 09:23 PM   #16
Xaperez100's Avatar
Oh okay thanks!
Old 05-02-2013, 02:36 PM   #17
Xaperez100's Avatar
Removing rear sway bar
Tools you need.
Jack, jack stand, x bar, and 13mm socket
Remove tire of course.
There's the first bolt and the second ones a little to the left.
Unscrew both and them repeat on other side.
P.s. if you're swapping it from another vehicle like myself then you'll have to get the nuts from the other car and put them on the car you're getting the bar from so the bolts can go back into place
ID:	105647   Click image for larger version
Old 05-02-2013, 02:44 PM   #18
Xaperez100's Avatar
Installing rear sway bar
Using same tools as removal except add another of jack
When you get it jacked up and look for the bolts when installing there will only be one on each side instead of two. So just remove them.
(Also when installing you'll have to bolts to put back in on each side where the old ones went or new ones will go.)
Now I did it by myself so I used a jack to hold up the sway bar in place. And screwed in the bolts for this side.
After putting the first bolt in I couldn't get it to stay straight or even. So I put the jack on the other side and lifted the sway bar into its position on the other side and I was able to position it on the side I was working on.
Then do the same for the other side and that's it!
Old 05-02-2013, 03:11 PM   #19
SpeedyG's Avatar
I would never trust those scissor jacks for anything. Especially if your going under the car. $60 can get you a heavy duty one at autozone. Safe than sorry bro.
SpeedyG is offline   Reply With Quote
Old 05-02-2013, 03:23 PM   #20
Xaperez100's Avatar
Lol don't worry I only used it to hold the sway bar in place:p I used my jack from the reply about unistslling^^ above
Old 05-02-2013, 04:11 PM   #21
SpeedyG's Avatar
+11111
Scared me for a second !!!
Old 05-02-2013, 04:45 PM   #22
Xaperez100's Avatar
+11111
Haha:p yeah I don't trust them either:p
Old 05-03-2013, 04:12 AM   #23
Skargon's Avatar
I always use a scissor jack, with jack stands.
Never go under a car without Jack stands, even with a 500$ jack.
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 05-03-2013, 07:46 AM   #24
Xaperez100's Avatar
I used jack stands also:p
04:09 PM
