Removing 7.5 - Mustang Evolution
Old 04-30-2013, 08:44 PM   #1
Xaperez100's Avatar
Removing 7.5
Anyone know how to? And if I could use basic tools to do it?
Xaperez100 is offline   Reply With Quote
Old 04-30-2013, 08:46 PM   #2
sam62893's Avatar
Do you have like a GT donor car or something? Hahah but yeah basic hand tools should do it. And at least two jacks or something special to hold the rear when you unbolt it
Old 04-30-2013, 09:01 PM   #3
Xaperez100's Avatar
Haha yeah it's just sitting here.-. Lol
Old 04-30-2013, 09:10 PM   #4
Ghostedmind's Avatar
Send me the rear bumper, the rear end, etc. hell just send the whole engine over, lmao
LCMC Member
Old 04-30-2013, 09:36 PM   #5
Blovett55's Avatar
Yes, taking it off is fairly simple, and basic tools will work
I'm not saying it's going to be a quick job, but fairly simple
You should definitely plan to at least have your car out of commission for one day, if you're doing it your self, That is if you're like me, where I start one thing, get sick of working on it, move to another part on my car for a couple hours, and then go back and finish it
Blovett55 is offline   Reply With Quote
Old 04-30-2013, 10:18 PM   #6
Xaperez100's Avatar
Lmao-.- I gotta ask my cousin if he wants to give those things away lol
---------- Post added at 10:18 PM ---------- Previous post was at 10:17 PM ----------
Nah I usually work on whatever I'm doing then the next. But what all do I need to remove? Control arms?
Old 05-01-2013, 03:16 AM   #7
Blovett55's Avatar
Well it depends how much of the rear end your cousin is giving you, I.E. struts,tires, arms
If its a 100% complete rear end, you can just take everything seen on the rear out and jack the new rear up into the car, bolts will most likely match, as long as your not putting say a 09 posi in a 01 v6
Old 05-01-2013, 11:52 AM   #8
Xaperez100's Avatar
Haha nah it's an 03 gt
And well he said I could have it. But what's easier to do? Remove all that or just one piece?
Old 05-01-2013, 12:47 PM   #9
sam62893's Avatar
Why not just take the GT?
Old 05-01-2013, 01:11 PM   #10
SpeedyG's Avatar
+1
SpeedyG is offline   Reply With Quote
Old 05-01-2013, 01:33 PM   #11
Blovett55's Avatar
I personally would remove it all and put his whole set up on, u cld just buy the gears to put in your existing, just can't super horse play, gears only cost like $200-$300
Old 05-01-2013, 04:19 PM   #12
Xaperez100's Avatar
Doesn't work. Everything f'd up lol
---------- Post added at 04:19 PM ---------- Previous post was at 04:18 PM ----------
Would I need gears?
Old 05-01-2013, 06:14 PM   #13
Blovett55's Avatar
What I am saying Is to forget the GT rear end for one second, Your present 7.75 rear end, can have new gears put into it, you can even buy the gears to turn into a Positrac, it's not like the 8.8, but if you don't horseplay every time you drive your Mustang, you can get away with this, this set up will cost you approximately $300-$400 tops
All you do is drain your rear and, put the new gears then, refill your fluids, and drive it with a posi in your 7.75 present rear end
But, if you're already getting AGT rear end for free, you might as well use that, just a lot more work Then changing the gears and your present one
Old 05-01-2013, 06:22 PM   #14
Xaperez100's Avatar
Oh okay. I see thanks for the info! But yeah I'd rather spend my time then money. Lol
Old 05-01-2013, 08:25 PM   #15
Blovett55's Avatar
Hey, I hear you, I'd rather spend my time then my money too, I don't blame you if you have a GT rear end, deff use it
We actually did the gears in my 7.75 for a little while before I switched to posi, now if you haven't been around posis your whole life, you won't tell the difference between the two, but I am 18, and have been around cars my whole life, and if you have and you know these feelings, there is a slight difference, but not much
The point though, is if you don't want to tear everything out of your rear end, you do have the option to spend a little money and end with the same result
Like I said though, if you're just going to do the swap, plan for at least one day to have a different car, because your Mustang will be out of action
Old 05-01-2013, 08:50 PM   #16
Xaperez100's Avatar
Haha yeah I hear you but I've only actually really been into cars since my senior year (two years ago) I'm graduated now. But since then I've learned a lot but no nothing about posis.. If you don't mind explaining what exactly it is?
And haha yeah ill probably just do it on Saturday so I can have all day. And won't have to worry about driving anywhere:p
Old 05-01-2013, 08:56 PM   #17
Blovett55's Avatar
In short, posi traction is short form for Positive Traction. It is also called Limited Slip Differential, but posi trac is a GM term. Posi is a differential that applies power to both wheels (mostly in high performance cars) and senses when one wheel starts spinning, so it reduces power to that wheel using a clutch mechanism (it's automatic). A common situation is when your turning, the power is reduced to the inside wheel so that you can turn, otherwise the car would be very difficult to turn. Differentials that apply the same power to both wheels at all times are call Lockers, and used mainly in drag racing cars. All non performance and sub compact cars use open wheel, which means power only goes to one wheel at all times.
This probably sums it up fairly well
Old 05-01-2013, 09:06 PM   #18
Xaperez100's Avatar
Oh!! Okay thanks for the info!
Old 05-01-2013, 09:08 PM   #19
Blovett55's Avatar
No problem man, lemme know how the gt rear end goes, on another note though, I tould you about me getting the louvers yesterday, my smoked headlights came today, awesome look, sealed them and instantly put on car
Old 05-01-2013, 09:46 PM   #20
Xaperez100's Avatar
Oh yeah show some pictures!
Old 05-02-2013, 01:45 AM   #21
Blovett55's Avatar
Will do first thing in the morning, changes the look of the car completely
Old 05-02-2013, 06:00 AM   #22
Blovett55's Avatar
Changes the fronts look 100%
Old 05-02-2013, 06:46 AM   #23
Xaperez100's Avatar
Yeah it does! You saw my before and after picture right?
Old 05-02-2013, 06:58 AM   #24
Blovett55's Avatar
I don't believe so
Old 05-02-2013, 07:51 AM   #25
Crowned1's Avatar
looks good! look even better with a chin spoiler
Crowned1 is offline   Reply With Quote
Old 05-02-2013, 08:27 AM   #26
Blovett55's Avatar
One thing at a time, that'll be on but next is smoked out fog lights
Old 05-02-2013, 12:41 PM   #27
Xaperez100's Avatar
I don't believe so
Old 05-02-2013, 01:04 PM   #28
just taking out the rear end is very easy, lower control arms, upper control arms, shock mounts, then brake lines BAM thats about it. If you have ABS undo those electrical connections.
Old 05-02-2013, 01:07 PM   #29
Blovett55's Avatar
Not to shabby
Lol
Old 05-02-2013, 03:13 PM   #30
Xaperez100's Avatar
And drive shaft:p
---------- Post added at 03:13 PM ---------- Previous post was at 03:13 PM ----------
Not to shabby
Lol
Haha yeah she's grown to be a beauty!
Old 05-02-2013, 03:16 PM   #31
Blovett55's Avatar
Lol ya I want to get a hood also soon, thought about carbon fiber
Old 05-02-2013, 03:48 PM   #32
Xaperez100's Avatar
Same here.!
Old 05-02-2013, 08:25 PM   #33
Blovett55's Avatar
These 2 r my favorite
Old 05-03-2013, 01:01 AM   #34
Xaperez100's Avatar
I like the first one:p Nd I like the termi hoods
Old 05-03-2013, 05:36 AM   #35
Blovett55's Avatar
See my other mustang has a normal 3 inch cowl hppd
07:59 AM
