car stalling out problem - Mustang Evolution
Old 04-30-2013, 09:48 PM   #1
mustangmiguel's Avatar
Region: New Mexico
Ok well my 95 3.8 mustang has a problem when its really hot and sunny out my car stalls out and wont turn on i jave to wait 10 minutes before it turns on then stalls out acouple minutes later i have to keep repeating untill i get home but when its nice out like afternoon with no sun it works perfect (i changed fuel pump and filter i changed coil pack and maf sensor) what is it guys i really need help
mustangmiguel is offline   Reply With Quote
Old 04-30-2013, 09:55 PM   #2
Ghostedmind's Avatar
I'm going to list of some things just to try to narrow it down on what you have and havent done.
Clean MAF (you said you changed it)
Clean Idle Air Control (IAC) Sensor
Clean/Replace air filter
Replace spark plugs
Replace spark plug wires
Replace Coil Pack (you said you did)
Replace fuel filter
Refill Radiator
Is there a SES/CEL on?
Is it overheating?
When it dies and you try to crank it what kind of noise does it make?
When it is running, does it run correctly or does it sound like it's stumbling any?
If you are able to, try to get a video or something to help us out a little
LCMC Member
Old 04-30-2013, 10:21 PM   #3
Region: New Mexico
Well it sounds like if it would be out of gas but its not and when its nice out like no sun or cool out it works perfectly fine no problems at all problems just come up when its hot and sunny outside air filter i replace it 2 months ago i am defenetly going to clean the rest of the parts you said whatvelse do you think it is
---------- Post added at 10:21 PM ---------- Previous post was at 10:19 PM ----------
Whats an ses/cel??
Old 04-30-2013, 10:40 PM   #4
SES = Service Engine Soon
CEL = Check Engine Light
Have you changed your fuel filter out? since you said you changed your fuel pump i doubt its that unless you didn't get a new one and got a junkyard/referb. it sounds like theres a possibility that there is a air lock forming in your fuel lines from water in your fuel (i.e. bad gas) or your fuel filter is so clogged that its suffocating your engine. I'd change out your fuel filter first (if you haven't already) because its only about $3 to get a new one.
Either way, to me it sounds like something is creating a lean condition in your engine. So the problem is somewhere between the fuel tank to the injectors if it is sputtering out like it's out of gas.
LCMC Member
Old 04-30-2013, 10:40 PM   #5
1slosix's Avatar
ignition module...syptoms of it going out would be malfunctions when it's hot but working when it's cooled down..i forget if the mid 90's models have them. pretty sure they do...if so pop it off and have any autoparts test it. i reccomend have a place test it at least 3 times to push it.
carving corners like a boss
Old 04-30-2013, 10:59 PM   #6
Region: New Mexico
Fuel filter got changed 2 months ago with the fuel pump fuel filter i bought it new and no engine lights are on or any light. Islo6 illchek it out also too see if its working properly thanks you two anymore ideas
Old 05-01-2013, 12:00 AM   #7
Region: New Mexico
Where is the ignition module located in my car?? And can it be the injectors??
Old 05-01-2013, 02:13 AM   #8
I don't know what kind of time or money capabilities you have, but you can hook up a pressure gauge to your fuel rail. If your pressure there is good (I THINK its supposed to be about 40 someone please post if you know for sure) then yes I'd check the injectors (if its not the ignition module)
LCMC Member
Old 05-01-2013, 02:25 AM   #9
Blovett55's Avatar
It has to be 40 because I know that 30 is low pressure
Blovett55 is offline   Reply With Quote
« Shaking | Halos »
10:22 AM
