need help with cats on my true duals! - Mustang Evolution
Old 05-01-2013, 08:24 PM   #1
Stangsquad's Avatar
Region: West Virgina
ok i just got my true duals all welded up, (paid $318 out the door) which included all the piping from cats back, hangers and two flowmaster 40s.. i asked if he could remove the cats and he said no because they can get fined. well anyways, its loud, but not loud like i want it. what should i do? the 40s are right after the cats so i thought about cutting the pipe abit after them instead of them comming out the back, but im not sure. would high flow cats make a big diff? and what about different header? please and thank you for your guys help!
Stangsquad is offline   Reply With Quote
Old 05-01-2013, 09:06 PM   #2
Torchredfrankie's Avatar
Off road H or X will solve your problem
Torchredfrankie is offline   Reply With Quote
Old 05-01-2013, 09:06 PM   #3
Project Pony's Avatar
Find a shop that will cut em out. Some won't, but some will if you pay cash. They usually won't give you a receipt either as to avoid getting slapped with huge fines. Go to a local place, the chain shops won't do it 99% of the time. I wouldn't bother with hi flow cats unless you need cats for inspection. And long tube headers will net you a few hp and a better tone.
I had my cats removed, prochamber installed, 2 1/2" piping and fowmaster 10's. Sounds loud, and good. A prochamber is a must on Mustang. Check out the exhaust sticky.
[SIGPIC][/SIGPIC]
Old 05-01-2013, 09:09 PM   #4
Stangsquad's Avatar
If I get an h pipe it just replaces where the cats used to be right ? And the just buy the mill sensors from am and ill be good to go ? What's the odds I got caught without cats ?
Old 05-01-2013, 09:10 PM   #5
Many people run without cats, including myself with no problems. You can have an h pipe and cats. But seriously look into an O/R Mac Prochamber.
[SIGPIC][/SIGPIC]
Old 05-01-2013, 09:14 PM   #6
You have the seat up cat less now? Link?
Old 05-01-2013, 09:14 PM   #7
Yes. I have no cats. Link to what?
[SIGPIC][/SIGPIC]
Old 05-01-2013, 09:15 PM   #8
For sound clip?
Old 05-01-2013, 09:15 PM   #9
Check out my videos in the exhaust sticky. Watch on a computer as most phones dont do the videos justice.
[SIGPIC][/SIGPIC]
Old 05-01-2013, 09:15 PM   #10
Stangsquad's Avatar
Can you explain what that is exactly ? Sorry..
Old 05-01-2013, 09:16 PM   #11
Here is one
[SIGPIC][/SIGPIC]
Old 05-01-2013, 09:25 PM   #12
Stangsquad's Avatar
What's the difference between that and a h or x pipe ? I looked on am they only have the mac prochamber listed for gts and cobra.
Old 05-01-2013, 09:29 PM   #13
Pro chamber fits a v6 too and X = more raspy sound not too deep and slightly more power upper end gains
H= deep sound with low end power gains
Old 05-01-2013, 09:30 PM   #14
You use the one for the gt on the v6.
The difference is amazing, that what the difference is.
[SIGPIC][/SIGPIC]
Old 05-01-2013, 09:33 PM   #15
Stangsquad's Avatar
Okay well thanks for your help guys !
Old 05-01-2013, 09:36 PM   #16
1slosix's Avatar
i love my prochamber...best of the midpipes imo
carving corners like a boss
Old 05-03-2013, 10:17 AM   #17
Casper54's Avatar
I have short headers an off road h pipe and flow 40's no cats there's a plug on american muscle that will delete the code so you can pass inspection. Sounds a lot better because of better flow. Def recommend.
Casper54 is offline   Reply With Quote
Old 05-03-2013, 11:21 AM   #18
Stangsquad's Avatar
What h pipe do you have ? Couldn't I just cut them and make my own ? Or just two straight pipes connecting the headers and the rest of my cat back?
Old 05-16-2013, 09:28 PM   #19
Casper54's Avatar
I have bbk o/r h pipe you could cut and weld it together if your good at welding but to cut a hole in two pipes and weld that would be hard. And if you ran just single pipes back you won't get a good rumble because the air is just free flowing not going in different directions to cause more back pressure and a deeper rumble. Also if you add a cai and throttle body spacer or the 65mm from am sounds better too.
02:44 AM
