Push rod guides - Mustang Evolution
Old 05-03-2013, 10:40 AM   #1
97cutomstang's Avatar
Push rod guides
Has anyone installed these in their motor before? Would you recommend them? Thanks.
97cutomstang is offline   Reply With Quote
Old 05-04-2013, 09:34 AM   #2
Anyone??
Old 05-05-2013, 11:15 AM   #3
davidcseifert's Avatar
Region: Arkansas
Pushrods guide plates are only needed when swapping to roller rockers instead of pedestal mount like factory
blower/new cam soon
Old 05-05-2013, 11:49 AM   #4
Ok thanks. I am installing roller rockers. Where would you recommend getting the guides? I see that Tom morana racing has the but it says it requires screw in studs. And I don't have them.
Old 05-05-2013, 11:53 AM   #5
Region: Arkansas
All guide plates require screw in studs, you'll have to buy them, look on comp cams website they sell the arp rocker studs
blower/new cam soon
Old 05-05-2013, 01:43 PM   #6
samuelsmith's Avatar
This is what I bought from Jegs. Remember you need to have the heads pedestal mount shaved to align the proper roller geometry. So the heads need to be removed.
397-m-6529-a302 rocker pedestal arm shims
249-4835-8 guide plate adjusters 5/16
249-4502-16 rocker stud 3/8 magnum rocker arms 1.7 3/8 ultra pro magnum
4602-16 polly locks
the polly locks need to be shaved because they are too long. The ones that come with the rocker arms are too short.
249-7635-12 5/16 magnum pushrods 7.15
It is easier to go with Super Six.
05:13 PM
