cobra rear end - Mustang Evolution
Old 05-03-2013, 10:47 AM   #1
stang916's Avatar
cobra rear end
Could I fit a cobra rear end in my 04 v6 stang or does it have to be from a gt??
stang916 is offline   Reply With Quote
Old 05-03-2013, 10:56 AM   #2
Project Pony's Avatar
You could do a irs swap. From what I understand it is not quite as easy as doing an 8.8 swap, and obviously a good bit more expensive. But an irs is much better for handling. I'm actually glad the 2015's will be ditching the current setup and going irs.
[SIGPIC][/SIGPIC]
Old 05-03-2013, 10:59 AM   #3
stang916's Avatar
How is it harder?? Can u explain cuz I found one from a.cobra for $500
Old 05-03-2013, 11:02 AM   #4
You will need to change your driveshaft flange, shocks, springs, and exhaust. If it comes with all that plus all brackets and hardware it might be worth it.
Old 05-04-2013, 09:08 PM   #5
samuelsmith's Avatar
I wish I remember where I saw a detailed wright up on I.R.S. at. No much beats independent rear suspension. Wasn't a car called wildstang or something like that, that had irs?
Old 05-05-2013, 03:12 AM   #6
Skargon's Avatar
Which cobra rear end? Not all of the years of Cobra's came with IRS from what I've seen.
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 05-05-2013, 04:09 AM   #7
Venomouz831's Avatar
All 99-04 cobras had rear end for the exception of the 2000 cobra r
)02 Gt, Founder of WE2G
Old 05-05-2013, 02:02 PM   #8
Wrong. All 99-04 cobras including the r had irs.
99/01 cobra and 00R had 28 spline diff and 31 spline hubs. 03/04 cobra had 31 spline diff and hub.
Old 05-05-2013, 03:17 PM   #9
I stand corrected
04:29 PM
