Horrible smoked headlights light output - Mustang Evolution
Old 05-04-2013, 12:59 AM   #1
sam62893's Avatar
Is it just me? Or do the smoked headlights have horrible light output? I got the car with smoked lights already so I'm not sure what they look like new. Any suggestions for getting better light? I almost pooed my pants earlier because there was a cop in front of me and I thought my lights weren't on haha first picture is normal lights and second is hi-beams
ID:	105979   Click image for larger version
Old 05-04-2013, 01:03 AM   #2
1slosix's Avatar
here's the only good way to fix that
DDM Tuning 35W and 55W HID Kits
carving corners like a boss
Old 05-04-2013, 01:10 AM   #3
sam62893's Avatar
Which wattage would you recommend?
---------- Post added at 02:10 AM ---------- Previous post was at 02:06 AM ----------
And also what else should be ordered from DDM? I don't play around much with my lights, it's not my territory lol
Old 05-04-2013, 01:12 AM   #4
1slosix's Avatar
when i ran smoked i needed 55w's to really make it worth it. eventually i went back to oem housings. as for what else you need just whats in the kit.
Old 05-04-2013, 01:17 AM   #5
sam62893's Avatar
Ill get 55w then. Thanks what about bulb and color? I read on some other posts that 6k is good. And I won't need harness or brackets right?
ID:	105981   Click image for larger version
Old 05-04-2013, 01:18 AM   #6
1slosix's Avatar
i like 6k's...as for harness some people need the relay kit in the end to keep flickering from occuring and some never do. i know i didn't with my 55w's...brackets are up to you. you can either build your own or buy them.
Old 05-04-2013, 01:19 AM   #7
1slosix's Avatar
bulb is 9007 btw...your choice if you want just a low beam or high and low beam
Old 05-04-2013, 02:09 AM   #8
sam62893's Avatar
Okay thanks man. Just ordered the 55w 6000k bulbs with brackets. Total came up to around $60 ill post pictures when they get here and before and after pictures
Old 05-04-2013, 02:37 AM   #9
MidnightBlueGT's Avatar
Idk why yours are illuminatinf so poorly. My lows are better than your highs haha.
---------- Post added at 04:37 AM ---------- Previous post was at 04:36 AM ----------
Illuminating*.
And yeah some hids should fix it though.
Im thinking of getting some myself.
Old 05-04-2013, 02:44 AM   #10
Venomouz831's Avatar
Those hids will surely fix the problem
)02 Gt, Founder of WE2G
Old 05-04-2013, 05:31 AM   #11
sam62893's Avatar
Hopefully haha ill keep you guys updated. For the $60 bucks they're worth, I better get some decent lighting
Old 05-04-2013, 11:00 AM   #12
greenstang41's Avatar
That's how mine where until I got hid
greenstang41 is offline   Reply With Quote
Old 05-04-2013, 02:40 PM   #13
Xaperez100's Avatar
Yeah hopefully they're good I paid $150 for my kit-.- lol
Xaperez100 is offline   Reply With Quote
Old 05-04-2013, 02:42 PM   #14
1slosix's Avatar
Wow what did you order and from who to pay that?
Old 05-04-2013, 02:43 PM   #15
Xaperez100's Avatar
This local shop that usually does things cheap but now I'm seeing that I got jipped. Lol but whatever it's too late now. At least they look good:p
Old 05-04-2013, 02:51 PM   #16
1slosix's Avatar
Lol yeah lesson learned
Old 05-04-2013, 02:52 PM   #17
sam62893's Avatar
Damn that sucks man. I hope these are good, I've heard good things about them on this forum. And one more thing, how exactly do we "aim" the lights. I've never had to do this
Old 05-04-2013, 02:56 PM   #18
1slosix's Avatar
There is an adjustment screw on the top of each housing. Just use a Philips head...turn one way for up and one way for down
Old 05-04-2013, 03:28 PM   #19
Xaperez100's Avatar
Haha yeah I know well at least they work good:p
Old 05-04-2013, 05:20 PM   #20
Torchredfrankie's Avatar
What's the best clear coat in a can I can use too put on smoked taillights I'm using Night shades can.
Torchredfrankie is offline   Reply With Quote
Old 05-04-2013, 05:24 PM   #21
sam62893's Avatar
I used red nights shade to fix my ex mother in laws tail light and I used no clear coat. Just 3 or 4 light coats. I used it as well on my third break light and they still look the same
Old 05-04-2013, 05:25 PM   #22
I want them to have that gloss finish how can I get that?
Old 05-04-2013, 05:27 PM   #23
1slosix's Avatar
High gloss clear..its what I use by duplicolor
Old 05-04-2013, 05:30 PM   #24
What grit did you use to sand down after I was thinking 2000
Old 05-04-2013, 05:31 PM   #25
sam62893's Avatar
It's okay to run them without the clear right? Wont give me any problems down the road?
Old 05-04-2013, 05:34 PM   #26
They say its safer to put clear in to protect lol
Old 05-04-2013, 05:37 PM   #27
1slosix's Avatar
I use trizac to finish (3000 grit)
Old 05-04-2013, 05:51 PM   #28
Okay thanks going to do my buddy's Tacoma
Old 05-04-2013, 05:54 PM   #29
Both done with VHT, neither have clearcoat.
Old 05-04-2013, 06:19 PM   #30
Personally i'd replace with non tinted housings.
Old 05-04-2013, 06:34 PM   #31
Ghostedmind's Avatar
Also, my Raxiom headlights I have looked pretty bad, I replaced the bulbs that came in it with silverstar ones (the gold package i think, whichever one has the 50% on it) and now it's a million times better
LCMC Member
Old 05-04-2013, 06:59 PM   #32
Done
Old 05-07-2013, 09:46 AM   #33
Stangsquad's Avatar
Region: West Virgina
If u want gloss u need to follow this. Sand them down with 1500 clean spray 1-3 light coats of nightshade. Then buy any can of gloss clear and spray atleast 5 coats. Gradually make the coats thinker but don't let it run. Wait over night to dry. Then WET sand 2000 grit untill all orange peel is gone. Now sand with 2500 grit and after scrub the heck out of it with rubbing compound. It will look shinny but a little dull use car wax (their painted now Remember) and now they will look like mirrors. Just take your time. I did mine and they're soooo glossy I'm verry happy.
Stangsquad is offline   Reply With Quote
Old 05-08-2013, 08:26 PM   #34
willrad00's Avatar
Do you if you have the Dark smoked Mustang headlights or just the smoked oem ones from AM?
03 v6- black 17' 03 Cobra R deep dish wheels, AM short shifter, divorced duals with original 40's, windstar swap, and a tuner!
willrad00 is offline   Reply With Quote
Old 05-08-2013, 10:57 PM   #35
sam62893's Avatar
I'm not sure. I know they're aftermarket for sure. I traded my friend and he told me that he replaced them after a trailer broke his light and messed up the car a bit
09:48 PM
