How do I install strut bar - Mustang Evolution
Old 05-04-2013, 07:34 PM   #1
Torchredfrankie's Avatar
Okay how do I install the back side of this strut bar to my stang can't seem to figure it out!!!! Please help!!!
Torchredfrankie is offline   Reply With Quote
Old 05-04-2013, 07:43 PM   #2
Ghostedmind's Avatar
To the firewall, These should help you out some, it's not for the BBK one but should still help out
American Muscle SR Strut Tower Brace Installation Instructions
SR Strut Tower Brace AM User Installation Instructions
LCMC Member
Old 05-04-2013, 07:48 PM   #3
DWC_SmOziLLa's Avatar
Basically how it goes is the supplied bracket mounts to the pinch weld on the firewall, and the stb mounts to the bracket. When you go to put that plastic trim piece back on you'll have to trim it a little. What you do is first mount the bracket to the stb, then set it in the engine compartment to mock fit it so I could mark the locations to drill through the firewall pinch weld. Then drill the holes... Mount the bracket (flat side facing the firewall), then the stb to the bracket. Then drill the the shock tower mounting points. You'll probably need to jack the car up on either side so the tires drop out of your way so that you can reach up inside there to put the nuts onto the studs coming down from the tower.
Old 05-04-2013, 08:56 PM   #4
samuelsmith's Avatar
I put the bar where it goes then marked the wholes with a marker. Yea, you will need to pull out the crow for the 2 bolts near the windshield. I did not jack mine up or hit a tire. I just had to contort my hands to get the bolts in.
Old 05-04-2013, 10:18 PM   #5
1slosix's Avatar
i had to jack mine up lol but with my car there just isn't room in the wheel well
carving corners like a boss
Strut Tower Brace Install 1slosix Pre-2005 V6 Mustang 8 07-27-2013 06:22 PM
J&M adjustable Pan Hard bar back n a stang Mustang Parts for Sale and Wanted 22 12-26-2012 06:15 AM
My Paxton Install Experience Jukens 2011-2014 Mustang GT 30 09-01-2012 04:35 PM
rear strut bar kickerofdoom Pre-2005 V6 Mustang 4 11-03-2011 06:47 PM
saleen roll bar install..... rinfield2004 Mustang Paint, Appearance & Detailing 5 07-13-2011 02:28 PM
06:18 AM
