4.2 badges, just got them today. - Mustang Evolution
Old 05-05-2013, 01:15 AM   #1
lemons95's Avatar
I think they look pretty good.
Old 05-05-2013, 06:32 AM   #2
rghoover3's Avatar
Why 4.2
rghoover3 is offline   Reply With Quote
Old 05-05-2013, 07:31 AM   #3
sam62893's Avatar
4.2 stroker. They look nice. The rear one isn't my cup of tea and I think you should take the tri-bar and pony off and just leave the 4.2. But that's just my taste. If you like it, keep it
Old 05-05-2013, 07:34 AM   #4
1lowGT's Avatar
Agreed ditch the tri bar. It'd look way cleaner
---------- Post added at 07:34 AM ---------- Previous post was at 07:33 AM ----------
And don't care for the deck lid. That's just me though. Looks better on a new edge when they are on the deck kid
Old 05-05-2013, 07:35 AM   #5
rghoover3's Avatar
How much does the stroker put out
Old 05-05-2013, 07:39 AM   #6
sam62893's Avatar
If I remember, it was 40-60 more hp than stock. I cups be wrong. And it also depends on whether you went split port or kept the single port setup. In his case, he stayed with the single port
Old 05-05-2013, 07:47 AM   #7
Mustang81596's Avatar
So how much would it be with the slip port swap also? I though that itself adds 35-50hp o.o
pypes x w/flow 40's, SR CAI, plasti dipped (emblems, stripe, rear decklid, rear valance, cowl vent grille, fuel door, antenna holder), shorty antenna, mach 1 chin spoiler, custom interior trim, blue LED interior lights, more to come later
Mustang81596 is offline   Reply With Quote
Old 05-05-2013, 08:03 AM   #8
ProjectTurboV6's Avatar
The split port swap adds 40hp to our 150, but that is to the crank. It also varies wither you have the windstar upper intake or not, its much lighter and has better airflow. With the swap, dual exhaust, and the windstar you would have an estimated 185-190rwhp
ProjectTurboV6 is offline   Reply With Quote
Old 05-05-2013, 08:10 AM   #9
1lowGT's Avatar
I don't see how adding that will get you 40hp more at the crank and then few new bolt ons getting you 190 at wheels. If you get 190 at the crank with adding the stroker then more mods shouldn't be at 190rWhp. But I don't know anything about this swap. So I guess I could be wrong.
Old 05-05-2013, 08:22 AM   #10
sam62893's Avatar
Correct me if I'm wrong, but doing the split port swap on a single port is just like adding another mouth to your engine haha. I have spit port on my new edges and I've never driven an sn95 so I can't tell you the power difference. Stock, the sn95 gets around 140-145 stroking it gets you at around 170-180 if I remember correctly. If you go spit port you can add the windstar upper intake which will help out tremendously. And also intake and exhaust. All that could get you a buttload more power compared to the completely stock motor. I've never done any of these mods, just researched them so don't take my word for it
Old 05-05-2013, 08:25 AM   #11
1lowGT's Avatar
Well still if you haw 190 at crank that and sdd more parts to get you to say 230 at the crank and that's probably over estimating it but that is only 180 at wheels. But idk
Old 05-05-2013, 08:40 AM   #12
sam62893's Avatar
But after the 4.2 stroke and windstar intake, there is pretty much nothing else you can do other than going with FI and nitrous
Edit: power wise
Old 05-05-2013, 09:14 AM   #13
1lowGT's Avatar
Exactly. But I was just debating the hp numbers
Old 05-05-2013, 09:24 AM   #14
It only takes 5-10hp to spin the flywheel/drive shaft so I wouldn't think at 220hp it would drop to 180-185 to the wheels...
Old 05-05-2013, 11:10 AM   #15
davidcseifert's Avatar
Region: Arkansas
4.2 bottom end adds max of 5hp and about 15tq at crank it's not that big of a difference.. Unless you spent the money and went forged with high compression then it adds more
just an FYI you lose .2 compression 3.8 swapping to 4.2 because of the dish in the pistons the f150 bottom end has
---------- Post added at 11:10 AM ---------- Previous post was at 11:09 AM ----------
Edit: power wise
Heads cam ported lower intake...
blower/new cam soon
Old 05-05-2013, 11:16 AM   #16
sam62893's Avatar
Ahhhh, I had a feeling I was missing something. Thanks
Old 05-05-2013, 01:57 PM   #17
samuelsmith's Avatar
[QUOTE=davidcseifert;1637151]4.2 bottom end adds max of 5hp and about 15tq at crank it's not that big of a difference.. Unless you spent the money and went forged with high compression then it adds more
When you change the cubic displacement of a engine, you change the compression. My piston is bored 30 and I have a 9 to 1 compression. The way to up the compression if this is a issue, is to use a dome piston.
Old 05-05-2013, 02:16 PM   #18
lemons95's Avatar
It feels like I gained more than 5hp and 15tq, but the last engine was over 160,000 miles.
Old 05-05-2013, 03:13 PM   #19
lemons95's Avatar
Also, I was going to remove the tri-bars. Since they are broken. I just don't know how, and I don't want to mess up the paint.
Old 05-05-2013, 03:44 PM   #20
sam62893's Avatar
Just get a towel and a scraper and take it off. It's just double sides tape
Old 05-05-2013, 04:23 PM   #21
Ghostedmind's Avatar
I thought all the side emblems had pegs/screws that went through the body...
LCMC Member
Old 05-05-2013, 04:30 PM   #22
sam62893's Avatar
I took the emblems off of my new edge and it had pegs and a hole, but that was just to get good placement.
10:29 PM
