Fuel help - Mustang Evolution
Old 05-06-2013, 08:57 PM   #1
sam62893's Avatar
Fuel help
Some of you may know that I'm dropping an 02 V6 engine into a 97 shell. I'm still stuck on the fuel lines and fuel tank. I can't seem to get the tank to fit so ill just drill a few holes here and there to stick it in. And the fuel delivery system is confusing me at times I got almost everything layed out but I don't know where the two hoses on the left side of the tank go? Is it the fuel shut off switch? And yes the lines and tank are from a NE. Just need help where to connect hoses.
ID:	106507   Click image for larger version
ID:	106509   Click image for larger version
ID:	106511   Click image for larger version
Old 05-06-2013, 09:40 PM   #2
samuelsmith's Avatar
I am not a 100% shure. Think they go to the canister.
Old 05-07-2013, 08:53 AM   #3
sam62893's Avatar
Ill remove the fuel canister and see what's up. I also have to replace the tank hoses because their broken and cracked
11:14 PM
