E brake not working - Mustang Evolution
Old 05-07-2013, 03:44 PM   #1
Robbiemustang96's Avatar
E brake not working
Ok so my 98 verts e brake doesnt work. Like the handle has the tension but it seems like someone wore the brake pad down and it doesnt grab anymore. Now 2 questions. 1 where is that brake pad located and 2. How do i get to it
Robbiemustang96 is offline   Reply With Quote
Old 05-07-2013, 05:15 PM   #2
Xaperez100's Avatar
I heard its hard to change the rear brakes on our cars. Not hard but you need a certain tool.
Xaperez100 is offline   Reply With Quote
Old 05-07-2013, 05:27 PM   #3
sam62893's Avatar
Are you sure it's the pads? They are just like the front brakes. If you need to replace them then you have to rent or buy a tool to push in the piston and no a c-clamp will not work. Check your cable and make sure it's connected right
Old 05-07-2013, 05:29 PM   #4
Xaperez100's Avatar
Yeah usually those dont go out because they're only really used to park. But yeah what he said^ lol I thought my c-clamp would work also.-.
Old 05-07-2013, 05:32 PM   #5
sam62893's Avatar
Rear brakes take YEARS to wear out. Depending on how you drive. But some people change them with the front pads.
I learned about the rear brakes the hard way on my cousins prelude. We ended up slipping the piston out of the socket it was a fun experience I guess haha
Old 05-07-2013, 05:37 PM   #6
So the e brake is just the regular brakes?
---------- Post added at 06:37 PM ---------- Previous post was at 06:36 PM ----------
And well my brakes need changed anyway cuz i have to push the pedal almost to the floor for them to actually stop me.. Otherwize they just slow me down some but wont stop me
Old 05-07-2013, 06:11 PM   #7
Xaperez100's Avatar
They're just smaller brake pads. But that's it. It' just requires a special tool to change then. And well yeah def change them soon!
---------- Post added at 07:11 PM ---------- Previous post was at 07:10 PM ----------
Yeah they do! And mine went out last year after years lol I started rolling back on my drive way I'd have to pull the e-brake hard and now it's just three clicks and it's good lol
Old 05-07-2013, 06:20 PM   #8
sam62893's Avatar
If you have to push the pedal all the way down then you might want to check the brake fluid
Old 05-07-2013, 06:39 PM   #9
sam62893's Avatar
Luckily I have a 97 in my garage that I'm working on
Here us the e brake cable
Then this is the normal brake hose
Then this is the brake pad. Car itself has 122k miles I have no idea when the PO changed the pads but the car has been sitting around for 9 years
ID:	106623   Click image for larger version
Old 05-07-2013, 06:43 PM   #10
samuelsmith's Avatar
Look at the springs and the teensier cable. That is your emergency brake. I think the cable is worn out, but not 100% shure. Pull the e brake and watch the spring and cable line.
Old 05-07-2013, 06:48 PM   #11
sam62893's Avatar
Yeah, jack your car up and check both sides take off your wheels and viola. Good luck, take pictures, and show us
Old 05-07-2013, 08:14 PM   #12
Brake fluids full..
---------- Post added at 09:14 PM ---------- Previous post was at 09:12 PM ----------
Ill have to do that when my dad feels better and we were gonna check the brakes anyway cuz he said that the pedal shouldnt have to move that much just to stop normaly
Old 05-07-2013, 08:46 PM   #13
sam62893's Avatar
Brake fluids full..
Hope he gets better soon. Yeah the brake shouldn't go down too much. Even with the brake pads worn down. You might have air in the lines
Old 05-07-2013, 08:55 PM   #14
Thanks. He had open heart surgery a week ago so i dont think we will be changin brakes any time soon unless he just tells me how to do it
02:34 PM
