Removing steering wheel - Mustang Evolution
Old 05-10-2013, 04:22 AM   #1
Xaperez100's Avatar
Anyone know how? I wanna plastidip mine without having to tape off everything so I'm thinking just take it off and dip it.
Xaperez100 is offline   Reply With Quote
Old 05-10-2013, 06:21 AM   #2
Project Pony's Avatar
The plastic column guards need to come off. Then the bolts holding on the airbag. Disconnect your airbag before doing this by the way! Once the airbag is out of the way you should be able to see the rest and figure it out from there. Its been about 3-4 years since I pulled the one in my 94. It's not difficult. You just need to take your time and have a decent set on hand tools.
[SIGPIC][/SIGPIC]
Old 05-10-2013, 06:53 AM   #3
sam62893's Avatar
Two of those on either side. Make sure to disconnect the battery for at least 10-20 minutes before servicing
Old 05-10-2013, 11:48 AM   #4
Xaperez100's Avatar
Okay cool thank you very much!
---------- Post added at 12:48 PM ---------- Previous post was at 12:47 PM ----------
Sweet!
Old 05-10-2013, 11:53 AM   #5
you need a puller to take the steering wheel off
Old 05-10-2013, 12:00 PM   #6
sam62893's Avatar
It makes it easier. But you can just pull it out by hand
Old 05-10-2013, 04:39 PM   #7
Skargon's Avatar
If you keep the nut loose, and not take it off all the way, you can pull as hard as you want and the nut will keep it from flinging off and punching you in the face.
If you want it easier, take the palm of your hand and bang from left to right sides of the wheel until it is loose, and pull it toward you.
Pulling my steering wheel was super easy.
1998 Mustang V6
CAI, Exhaust, Weight Reduction
16.5 1/4 Mile
Skargon is offline   Reply With Quote
Old 05-10-2013, 04:49 PM   #8
Xaperez100's Avatar
Now I'm scared lol
Old 05-10-2013, 05:36 PM   #9
sam62893's Avatar
Originally Posted by Xaperez100 View Post
Now I'm scared lol
Hahah but you just want to plastidip the airbag right? The pony airbag comes completely off. If you plastidip the actual steering wheel all the dip will probably rip off in 2 maybe 3...... Minutes depending on how you drive.
Take this for example. Where you see the lines, that what's gonna come off and you'll be left with the airbag holder AKA steering wheel
Old 05-10-2013, 05:39 PM   #10
Xaperez100's Avatar
Yeah I was just gonna dip everything and put the steering wheel cover back on so it won't get messed up
Old 05-10-2013, 05:41 PM   #11
sam62893's Avatar
It would be hard to put on a cover after the dip. It'll probably peel off. If I were you I would dip the airbag and use actual paint on the wheel
Old 05-10-2013, 06:45 PM   #12
Xaperez100's Avatar
Hmm okay ill see what I can do:p thanks!
Old 05-12-2013, 08:44 AM   #13
fastmustangs1's Avatar
I would disconnect the battery first before removing the airbag.
fastmustangs1 is offline   Reply With Quote
11:36 PM
