Help code reading - Mustang Evolution
Old 05-10-2013, 08:39 AM   #1
Vsixpower's Avatar
Help code reading
I just pulled a code off my 2001 v6 p1518 p1000 can sum one give me more details on how I can fix this prob and what this problem is
Vsixpower is offline   Reply With Quote
Old 05-10-2013, 05:06 PM   #2
1slosix's Avatar
P1516 Inlet Manifold Runner Control Input Error (Bank 1)
if i remember have someone rev the engine past 3250 rpms. There are 2 black cables that run into the back of the intake manifold. at 3250 rpms, those cables should jump/move. If they aren't, the IMRC's are not working.
carving corners like a boss
Old 05-10-2013, 09:21 PM   #3
Ghostedmind's Avatar
Did you mean to put 1516? because he put 1518.
P1000 - OBD System Readiness Test Not Complete
P1518 - Intake Manifold Runner Control Fault - Stuck Open
Either way what you should do is the same, see if the cables are moving.
LCMC Member
Old 05-11-2013, 12:21 AM   #4
Vsixpower's Avatar
Thanks for the help.... Is this problem bad in the long run if unfixed? Wouldn't happen to have a pic of what I'm looking for?? Thanks
03:42 AM
