Transmission swap - Mustang Evolution
Old 05-10-2013, 08:43 AM   #1
BlueMonster's Avatar
Transmission swap
How much does it cost to do a transmission swap from an automatic to a standard on my 03 v6
BlueMonster is offline   Reply With Quote
Old 05-10-2013, 09:10 PM   #2
Ghostedmind's Avatar
If you do all the work yourself anywhere from $1000 to $3000 Just depends on how cheap you can find the parts and if you go ahead and do upgrades you want, new or used transmission etc. What I have my swap priced at so far its somewhere around $1700, but since then i've found a few things a little bit cheaper.
Heres some good information on the T-5 Swap
Also there is a guy on here that has done it and was talking about doing a write up on it, you should be able to do a search and find his post.
---------- Post added at 10:10 PM ---------- Previous post was at 10:07 PM ----------
The guy i was talking about is GDogg08
And here are his threads:
T5 Swap Next Weekend!!!
After T5 Swap
LCMC Member
Old 05-11-2013, 12:03 PM   #3
Thanks man that helps alot
Old 05-11-2013, 12:11 PM   #4
Not a problem
LCMC Member
03:21 PM
