Brake upgrade - Mustang Evolution
Old 05-11-2013, 05:15 PM   #1
Surffer227's Avatar
Brake upgrade
Has anyone upgraded brakes on here? I wanna do it but not spend a fortune on the kits, wondering if I could use cobra 13 in rotors n caliper if I got the brackets would they mount up, or I just saw someone selling gt brakes off a 2010, think any of those brackets would mount up?
Surffer227 is offline   Reply With Quote
Old 05-11-2013, 09:29 PM   #2
samuelsmith's Avatar
What up grades do you have to need this brake system?
Old 05-11-2013, 10:45 PM   #3
Blovett55's Avatar
You could go with drilled and slotted rotors from tirerack.com, they have Brembo drilled front $72 a piece and $100 for rear a piece
But would be well worth it since its Brembo
They also have centri-posi calipers on the website also
All my tire needs I use them for since they're based out of Indiana and I live in ohio
---------- Post added at 10:45 PM ---------- Previous post was at 10:42 PM ----------
Sorry mispriced the rotors, $180 for a pair
Here's the link to rotors and calipers
http://www.tirerack.com/brakes/resul...0&autoModClar=
Blovett55 is offline   Reply With Quote
Old 05-12-2013, 12:07 AM   #4
1slosix's Avatar
i run SS lines, hawk pads, and a fluid swap and it's like a completely different car break wise.
carving corners like a boss
Old 05-12-2013, 11:22 AM   #5
Ghostedmind's Avatar
Just out of curiosity, how much do you pay for the SS brake lines?
Also, what fluid did you swap in there, i think i remember you said DOT 5 right?
LCMC Member
Old 05-12-2013, 12:35 PM   #6
davidcseifert's Avatar
Region: Arkansas
You can get SS lines for front and rear for ~$150 Russell Performance brand on summitracing.com
I just used brakemotive (ebay company) drilled/slotted rotors and the pads they came with for the past almost 3 years and still haven't had to replace the pads yet works great
blower/new cam soon
Old 05-12-2013, 01:47 PM   #7
I can build them for less than half that price...thats why I asked...
LCMC Member
Old 05-12-2013, 02:35 PM   #8
2Greeny7's Avatar
Send a message via Skype™ to 2Greeny7
I also run David's setup! Works really well and good bang for the buck!
2001 V6
CAI, SF3/X3 Tuner, 4.10 Gears, Auburn lim-slip
GT4 Rims (Summer), Stock Rims (Winter)
2 Subs, New speakers all around
1 Great Car 1 Happy Kid
July '12 Mustang of the Month
2Greeny7 is offline   Reply With Quote
Old 05-12-2013, 02:59 PM   #9
1slosix's Avatar
5.1 fluid NOT 5...5 is silicon based and is a no no. i run Gstop lines from Goodridge
04:57 AM
