What is 93 super unleaded gas for - Mustang Evolution
Old 05-11-2013, 06:47 PM   #1
greenstang41's Avatar
greenstang41 is offline   Reply With Quote
Old 05-11-2013, 06:51 PM   #2
MidnightBlueGT's Avatar
Superman's car
Old 05-11-2013, 06:54 PM   #3
Black8thElement's Avatar
93 race tune
Black8thElement is offline   Reply With Quote
Old 05-11-2013, 07:10 PM   #4
samuelsmith's Avatar
Put 93 in your car without a tune a see HOW BIG OF A DIFFERENCE YOU FEEL!
Old 05-11-2013, 07:31 PM   #5
Higher octane=better performance including mpg. I put 91 in mine
Old 05-11-2013, 07:42 PM   #6
Fourloko530's Avatar
Never seen a 93 in nothern cali bummer lmao
Fourloko530 is offline   Reply With Quote
Old 05-11-2013, 07:46 PM   #7
Ghostedmind's Avatar
at the same time, if your car is designed to run 87, you wont really notice anything on 93. If you get a tune for it you should. But 93 will allow a higher spark advance among a few other things which help with power
LCMC Member
Old 05-11-2013, 07:57 PM   #8
Old 05-11-2013, 08:07 PM   #9
Whats the highest grade you get?
Old 05-11-2013, 08:15 PM   #10
Does 2000 v6 mustang take 93 no tune
And what is the difference it makes
Old 05-11-2013, 08:22 PM   #11
it'll use it, but its not going to be as big of a difference as if you actually tuned for it.
LCMC Member
Old 05-11-2013, 08:29 PM   #12
I use 91 with tune how can get it to 93
Old 05-11-2013, 08:45 PM   #13
DustyStang306's Avatar
We got 94 in Canada
DustyStang306 is offline   Reply With Quote
Old 05-11-2013, 08:54 PM   #14
McNassty's Avatar
It's for advanced timing, if your running it without a tune you can actually cause deposits in your motor from early detonation
McNassty is offline   Reply With Quote
Old 05-12-2013, 05:55 AM   #15
Project Pony's Avatar
Find someplace that sells 93.
Mine is tuned, I run 93 non-ethanol.
If your not tuned for a higher octane than recommend, you will see no gains. That is a lot of research done backing that up. If you try, you are just wasting money.
[SIGPIC][/SIGPIC]
Old 05-12-2013, 07:21 AM   #16
tc x 4's Avatar
Higher octane if for higher compression pistons.
04:25 PM
