98 v6 - Mustang Evolution
Old 05-11-2013, 07:05 PM   #1
Fourloko530's Avatar
98 v6
So with cai,bbk pulley,h pipe,flow masters,bama tune,lower control arms ,alum drive shaft ,8.8 410 should i b running good times
Fourloko530 is offline   Reply With Quote
Old 05-11-2013, 08:08 PM   #2
joey18's Avatar
Only way to knowif forsure is geta out there and try
joey18 is offline   Reply With Quote
Old 05-11-2013, 09:18 PM   #3
Dammit hoey lol
Old 05-11-2013, 09:26 PM   #4
samuelsmith's Avatar
post track time
Old 05-11-2013, 09:32 PM   #5
joey18's Avatar
Dammit hoey lol
Lol how you been man?
Old 05-12-2013, 12:25 AM   #6
Don't act like we haven't talked in a while lol I'm just wondering what id b expecting from dis
Old 05-12-2013, 09:57 AM   #7
joey18's Avatar
I know lol
Old 05-12-2013, 12:40 PM   #8
davidcseifert's Avatar
Region: Arkansas
Mid-high 15's if you can drive good, single ports just don't have much top end
blower/new cam soon
Old 05-12-2013, 04:57 PM   #9
That's not bad after dat put a m90 in it
Old 05-12-2013, 05:01 PM   #10
joey18's Avatar
Then next mod... some tires with actual beef
Old 05-12-2013, 05:21 PM   #11
Lol yea i know lol but I'm on a diet still lol
Old 05-12-2013, 08:28 PM   #12
R the 390 gear good
Old 05-12-2013, 09:16 PM   #13
ProjectTurboV6's Avatar
Do a split port swap, +40hp, get a tune, +10hp, then you might break into the 14s and keep up with the GTs if you lighten her up a little bit.
ProjectTurboV6 is offline   Reply With Quote
Old 05-12-2013, 09:21 PM   #14
M90 sounds better
Old 05-12-2013, 09:26 PM   #15
Originally Posted by Fourloko530 View Post
M90 sounds better
The swap and tune is $400-500, cheaper than the m90... Unless you have deep pockets, then the m90 is definitely better. That would be faster than GTs
Old 05-12-2013, 09:35 PM   #16
I feel like swapping a 4.2 and m90
---------- Post added at 09:35 PM ---------- Previous post was at 09:31 PM ----------
I don't think id b expensive they got a couple up here for 300$ engine i just want the blower top
Old 05-12-2013, 09:46 PM   #17
Region: Arkansas
If you want a M90 buy supercoupe motor drop it in and then make the wire modifications needed etc..
blower/new cam soon
Old 05-12-2013, 10:21 PM   #18
andregayola's Avatar
how do u do the spilt port???
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 05-12-2013, 10:21 PM   #19
What u think david
Old 05-12-2013, 10:29 PM   #20
Its the top stuff lol
Old 05-12-2013, 10:33 PM   #21
Ghostedmind's Avatar
I believe the for the split port swap you need the upper and lower intake and the heads off of a split port engine. Basically the Power pack from Supersix and also I think the fuel rail, and mounting bracket for the coil pack....I know I'm missing a few things
LCMC Member
Old 05-12-2013, 10:35 PM   #22
that's alot of money he just said it costs less than 400$ could i do it with a wind star manifold ?
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:40 PM   #23
I'm not saying you have to get the power pack, you just need those items, i'm sure you can go get the Upper/lower intake, heads etc from a you-pull it and spend hardly anything and yes you could do it with a windstar manifold but you would still need the split port lower manifold.
---------- Post added at 11:40 PM ---------- Previous post was at 11:38 PM ----------
and i dont know about doing the swap AND the tune for 4-500...the tuner alone (at least from AM) is 380....even if you just get your ecu re-flashed that at minimum 150 i'm sure
LCMC Member
Old 05-12-2013, 11:30 PM   #24
Eli
Eli's Avatar
Region: Arkansas
My 01 next to a 98 and a 06 all v6
Eli is offline   Reply With Quote
09:33 AM
