FI OR SC - Mustang Evolution
Old 05-12-2013, 07:53 PM   #1
andregayola's Avatar
FI OR SC
what's beter and era more power for our cars a socket turbo and twin turbo or a kennith bell supercharger
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 05-12-2013, 08:15 PM   #2
Torchredfrankie's Avatar
I would have gone turbo but you have to make your manifolds ):
That's why I picked up a pro charger
Torchredfrankie is offline   Reply With Quote
Old 05-12-2013, 08:18 PM   #3
what's the difference? and how do u install
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 08:21 PM   #4
Turbo is exhaust driven and Supercharger is belt driven. Do some research on both before you chose. Turbo would be sweet because of a Blow off Valve but I love the way supercharge sounds and even more with a Bypass Valve. At the end it's what you like.
Old 05-12-2013, 08:34 PM   #5
MidnightBlueGT's Avatar
Research a ton before buying something like that!
Turbo needs more supporting mods because it puts out a lot more power unless on low boost.
I love both though.
Old 05-12-2013, 08:36 PM   #6
The Blue Dragon
GrabberBlue5.0's Avatar
Not sure what a socket turbo is ?? And it really kinda depends on what you want out of your car. They both have pros and cons as well
New quick exhaust video
AUGUST 2012 MOTM!!!!
Old 05-12-2013, 09:07 PM   #7
i want most power enough to beat my buddies gt
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 09:09 PM   #8
Bigger power=bigger price. What hp range are you wanting?
Old 05-12-2013, 09:10 PM   #9
he's pulling around 300 rwhp
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 09:14 PM   #10
Sc will easily make that.
What kind of stang do you got?
Old 05-12-2013, 09:16 PM   #11
1999 mustang v6 with a k&n intake and basically it for now lol im starting a build in June and wante to explore my possibilities
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 09:19 PM   #12
Sc will get you there and is cheaper than a turbo. Im not sure what the v6's internals can take so research whether or not stock internals need to be forged or not.
Id definitely do sc though if i were you and wanted that 300 range. I believe the v6's come with like 190hp and youll make about 250-350 depending on your boost level.
Old 05-12-2013, 09:24 PM   #13
ProjectTurboV6's Avatar
The stock internals can take up to 300hp, so around 8-10psi on a sc. You can slap that on your car now and be good to go, definitely can't say the same with a turbo. Basically, a sc will give you better bottom end power and a turbo will give you better top end. So sc will start out fast and a turbo will end being fast. It's all about preference.
ProjectTurboV6 is offline   Reply With Quote
Old 05-12-2013, 09:26 PM   #14
I wasnt completely sure so didnt want to suggest a peak range and give incorrect information.
So yeah i say get a sc with and inter or after cooler
Old 05-12-2013, 09:27 PM   #15
what about both is that possible or even smart an of course i would have all the supporting mods like forged and the exhaust... but could it be done and what power would i see
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 09:29 PM   #16
Hmmmm.... You might be able to do an exhaust turbo and an sc... Could put out 350-400hp if it works. I'm really not too sure
Old 05-12-2013, 09:30 PM   #17
It could be done, but a lot of work and forging.
I honestly wouldn't spend that kind of money on that kind of setup for a v6 or even my own. Huge money pit compared to what you'll get out of it compared to getting a 4v stang
Old 05-12-2013, 09:31 PM   #18
but in theory power wise and acceleration if sc geting power low end and tc high end then would it make the perfect combo
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 09:52 PM   #19
davidcseifert's Avatar
Region: Arkansas
The stock motor can take less than 400rwhp easily if tuned properly (detonation blows ***** up)
Used supercharge kits float around often for <$2000 supporting mods you can get cheap, focus pump or aviator pump both can be had for under $100, terminator injectors support all you'll need and are usually $150 or less
blower/new cam soon
Old 05-12-2013, 09:59 PM   #20
so if i get a sc and then some sporting mods i can beat my buddies gt?
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:11 PM   #21
It will put you in the same hp range. So it would be about even, depends on the driver
Old 05-12-2013, 10:13 PM   #22
oh okay how will I get mine to pass his power like let's say about 320 or 340 im looking to get a Kenneth bell sc from my buddies wrecked termi
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:24 PM   #23
Kenne bell*
Up the boost...SAFELY.
Don't push too far and blow your motor **** measuring.
Old 05-12-2013, 10:26 PM   #24
sorry lol and you think that will bump me up to past his hp and how will my torque look
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:29 PM   #25
Should. depends what psi you're at.
Old 05-12-2013, 10:30 PM   #26
okay sweat and i have a 8.8 rear available should i install it aswell?
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:37 PM   #27
Go for it. Having a lot of power is useless unless you can get it to the pavement
Old 05-12-2013, 10:41 PM   #28
Ghostedmind's Avatar
Why haven't you already done that? lol, yes, definately put the 8.8 in and get some gears. 3.73 for 5 speed and 4.10 for auto
LCMC Member
Old 05-12-2013, 10:52 PM   #29
yea but if i do the kenne bell install only cuz i wana do it all in one shot but i need to know of i can beat my buddies gt me n him have been at it for two years
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:53 PM   #30
any sort of FI you'll be able to get up there, just got to make sure you have it tuned right and make sure you have any supporting mods you need.
LCMC Member
Old 05-12-2013, 10:55 PM   #31
1slosix's Avatar
if you can afford this build why not just sell the v6 and look for a 4v? sn95 cobra's aren't pricey now-a-days lol.
carving corners like a boss
Old 05-12-2013, 10:56 PM   #32
yea i know his gt is bad *** but i think i can beat hi with the supercharger but i gota see how much money it's going to take
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:57 PM   #33
1slosix's Avatar
3-4 k
Old 05-12-2013, 10:57 PM   #34
it's my first car ie had a 02 gt and got rid of it i lovelies car the color the history and since I've crashed my gt i wante to make my 6 faster than my buddies gt an still have beter economy
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-12-2013, 10:59 PM   #35
1slosix's Avatar
you won't have better economy lol. you'll get a lot less then his GT if you're planning to make the same power as him.
10:43 PM
