Understeer - Mustang Evolution
Old 05-12-2013, 09:35 PM   #1
Surffer227's Avatar
Understeer
I've been trying to do some track racing lately and have noticed alot of understeer, on my 18s it wasn't so bad, when I stepped down to 17s I understeer all over, what's a good way to help this? I think imma get subframe connectors off the convertible
Surffer227 is offline   Reply With Quote
Old 05-12-2013, 10:47 PM   #2
1slosix's Avatar
the sfc off a vert are ok since you don't have any. however you should save for full length
carving corners like a boss
Old 05-13-2013, 06:26 AM   #3
Surffer227's Avatar
Is there really that big of a difference between them
Old 05-13-2013, 08:41 AM   #4
1slosix's Avatar
yes
Old 05-13-2013, 09:09 AM   #5
Surffer227's Avatar
Well anything other than that help
Old 05-13-2013, 11:02 AM   #6
bullitt1075's Avatar
Send a message via Skype™ to bullitt1075
Add some front camber. Possibly some caster also. This will aid in turn in.
---------- Post added at 05:02 PM ---------- Previous post was at 05:00 PM ----------
You can also add a stiffer rear sway bar.
Proud owner of Bullitt #1075
bullitt1075 is offline   Reply With Quote
Old 05-13-2013, 11:08 AM   #7
Camber bolts are less than $30, and will get you enough negative camber to make your car turn in much better. You can also go with camber/caster plates which are more expensive, but they will give you mare adjustment and allow you to add caster.
06:08 PM
