Rubbing sound - Mustang Evolution
Old 05-13-2013, 11:17 AM   #1
Region: Iowa
Rubbing sound
When I am going at a slow cruising speed , and go to turn my brakes in the rear start rubbing against the rotor what can cause this . I'm lost on ideas checked caliper and checked wheel and made sure pads are aligned
Iowaboy13 is offline   Reply With Quote
Old 05-13-2013, 12:07 PM   #2
andregayola's Avatar
are your pads worn or mabye there to thin and they rub when u break and did u install it urself could be the piston aswell
1999 V6
Sonic Blue
Mods - Eibach Super sports
Cold Air Intake
K&N Air Filter
Front sway bar Bushings
andregayola is offline   Reply With Quote
Old 05-13-2013, 12:18 PM   #3
Region: Iowa
The piston is what I was starting to think , if It goes out ill just replace them all with the sve kit
Old 05-13-2013, 12:21 PM   #4
just upgrade the calipers and the rotors all aroundand us as break lines and you'll be set lol
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-13-2013, 02:23 PM   #5
Region: Iowa
Right , what do you think is better slotted or drilled rotors
---------- Post added at 02:23 PM ---------- Previous post was at 02:21 PM ----------
What's do you think is better slotted or drilled rotors
Old 05-13-2013, 03:17 PM   #6
goodwinta1's Avatar
I bought a rear break hardware kit for the same reason, it came with the thin metal clips which were severely worn on mine. This helps to keep the pads aligned properly. It was a cheap $10 fix at autozone and they were actually in stock. It also comes with new bolts and boots if you need those.
goodwinta1 is offline   Reply With Quote
Old 05-13-2013, 04:02 PM   #7
slotted drill has tendency to snap
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
Old 05-13-2013, 04:32 PM   #8
sam62893's Avatar
Drilled rotors crack sometimes and make your brakes cry. I have drilled AND slotted rotors on mine. It has one tiny little crack and it screeches
Old 05-13-2013, 07:43 PM   #9
Region: Iowa
So slotted is the way to go then
Old 05-14-2013, 11:19 AM   #10
defiantly an it looks really cool lol if you get yelllow rotors with red calipers lol
1999 V6
Sonic Blue
Cold Air Intake
K&N Air Filter
03:41 AM
