TIME SLIP IN A 1/4 mile - Mustang Evolution
Old 05-16-2013, 08:49 PM   #1
Vsixpower's Avatar
R these times ok for a v6 01 with only a tune a cai n e suggestions or opinions on my times. Thanks
ID:	108621   Click image for larger version
Vsixpower is offline   Reply With Quote
Old 05-16-2013, 09:29 PM   #2
What app is that?
Old 05-16-2013, 10:04 PM   #3
Vsixpower's Avatar
It's CMS lap timer
---------- Post added at 11:04 PM ---------- Previous post was at 11:00 PM ----------
It's a good app it also tells u ur hp spd g force and with a data analysis with graphs
Old 05-16-2013, 10:16 PM   #4
1slosix's Avatar
My sixxer ran 16 flat stock so I guess the difference is you're talking street vs a prepped track
carving corners like a boss
Old 05-16-2013, 10:45 PM   #5
Vsixpower's Avatar
1 sec diff
Old 05-17-2013, 01:30 AM   #6
05 MUSTANG GT's Avatar
Do you haft to be on a track for the app to work
05 MUSTANG GT is offline   Reply With Quote
Old 05-17-2013, 02:40 AM   #7
davidcseifert's Avatar
Region: Arkansas
Unless it is connected with the OBD2 system and using the mileage counter of the car, I wouldn't even come close to trusting the accuracy of any of the "1/4 mile time" apps
blower/new cam soon
Old 05-17-2013, 08:01 AM   #8
Project Pony's Avatar
+1
[SIGPIC][/SIGPIC]
Old 05-17-2013, 09:50 AM   #9
Vsixpower's Avatar
The app uses ur phones GPS to track ur location and with ur phones built-in accelerometers but that's for an iPhone.
Old 05-17-2013, 10:42 AM   #10
1slosix's Avatar
Still it can't be close to accurate..that's why I assume you're time posted is way off. Like I said stock I was running much quicker.
Old 05-17-2013, 11:29 AM   #11
Civilian gps is not very accurate, there is a large margin of error. (I believe between 100-400 feet) For that reason, it cannot correctly give information (1/4 mile time) that requires very precise measurements.
I guided fire for 155mm Howitzers, even the gps systems that the military has access to wouldn't be accurate enough to calculate quarter mile times. That why we had to calculate firing coordinates manually.
[SIGPIC][/SIGPIC]
Old 05-17-2013, 11:56 AM   #12
Vsixpower's Avatar
That's what I wanted to hear a breakdown of why it won't be as accurate thanks. So should my times be quicker than, my tires didn't catch as quick as they would in a track.
Old 05-17-2013, 12:08 PM   #13
Your times will always be better at a track. The prepped surface makes a huge difference. Good luck when you get to a strip!
[SIGPIC][/SIGPIC]
02:39 PM
